07-11-2009, 10:52 PM | #1 |
WTB - 72 BBC Motor Mounts
As the title states. I'm looking for a set of 72 BBC Motor Mounts (towers, Engine Stands)
Dan 67 Chevy LWB, Small Window - In the process of being rebuilt. Small Block is coming out & I'm gathering parts to switch to a Big Block 496. |
08-09-2009, 10:39 AM | #2 |
Re: WTB - 72 BBC Motor Mounts
Still Looking. If you have some please e-mail me at
mga60 @ att.net
Dan 67 Chevy LWB, Small Window - In the process of being rebuilt. Small Block is coming out & I'm gathering parts to switch to a Big Block 496. Last edited by Dan 67 Chevy LWB; 08-09-2009 at 10:39 AM. |
08-09-2009, 10:43 AM | #3 |
Roadtrip!
I have a set of 71 stands, and 72 stands. $160 on the 72s, and $100 on the 71s shipped.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
08-10-2009, 03:24 PM | #4 |
what is the difference between the 71 and 72's. I have a set that came with a 72, but I am not sure if it was an original BBC truck.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
08-10-2009, 04:10 PM | #5 |
Under Construction
FYI, the attached pics are '72 only BBC mounts
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
08-10-2009, 09:51 PM | #6 |
Roadtrip!
First pic is 72 style, and second is 68-71...
08-10-2009, 10:48 PM | #7 |
thanks guys, mine are 68-71.
03-08-2010, 05:32 PM | #8 |
"something witty here"
which are the better set to get when looking to convert to bbc?
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
03-08-2010, 05:55 PM | #9 |
Under Construction
either one will work fine as both were made for BBC... iirc the 68-71 bill bolt right up, the 72 only will require drilling a hole on the xmember as it has 4 mounting points vs. 3 . someone will correct me if im wrong.
03-08-2010, 05:56 PM | #10 |
I Like Mine With No Shine!
I also think one sets rubber mounts are more expensive than the others. Might wanna look into that too.
Michael 1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day) 2006 GMC Sierra Crew Cab 4x4 1969 Lincoln Continental Coupe Project FOR SALE http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 1981 Honda CM400 C Bobber SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
03-08-2010, 08:41 PM | #11 |
Moderator
It's a trade-off.....The 68-71 rubber mounts are expensive, but the towers are less. The 72 rubber mounts are cheap, but the towers are more.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-08-2010, 09:14 PM | #12 |
Project Junkie! Fishing Poor!!
You shouldn't have to drill any holes for the 72s either. You already have 2 holes drilled in your crossmember. 1 for the small block frame bracket and the other for the 6 cylinder one. The 72 Big Block frame brackets utilise both of those holes. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
03-08-2010, 09:57 PM | #13 |
Dan after all the dust clears if you still need correct 72 engine stands we have a nice set with new mounts and all the mounting bolts for $200 plus shipping which should be less than $20.
Let us know...Paul and Jason
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
03-08-2010, 10:30 PM | #14 |
73-87 chevy truck mounts will work on 67-72 with drilling the one hole and are easier and less expensive to get have done this a few times with no problems also do not have to be for a big block ,small block towers will work too
03-08-2010, 11:55 PM | #15 |
Under Construction
Wes, thanks for the clarification on this.
03-09-2010, 10:56 PM | #16 |
I have a set of the 72 Only mounts... PM'd you.
