Old 07-12-2009, 01:24 PM   #1
JW76
JW76's Avatar
LS motors
I was visiting a friend the other day and talking about my truck and he offered me two LS motors. I asked how much, and he said for free. I went to his shop and picked them up. One is a 5.3 and the other is the 6.0. They are both out of 2005 vans. I scored. I'd like to use the 6.0 in my truck with the carb setup. Does anybody have any advice or experience on how to build a 6.0 for out trucks.
JW76 is offline   Reply With Quote
Old 07-12-2009, 01:49 PM   #2
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: LS motors
yeah i have some advise send them to me
im wanting to build a 6.0
i would leave the bottom end stock put on some l92 heads from scoggin dickey
head specs 2.16 int. 1.59 ex. valves they flow 320 cfm for $700 a pair!!
put on a gm carb intake and a comp cam
check this out for a better idea
link
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 07-12-2009, 02:30 PM   #3
moneyeater
moneyeater's Avatar
Re: LS motors
Ask pmcobra he just put a 6.0 into his truck.Good score btw!IŽd like to put the 5.3 in my truck but shipping it to germany wouuld bust every budget! :-(
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
Ž81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 07-12-2009, 04:09 PM   #4
JW76
JW76's Avatar
Re: LS motors
Thanks for the link to the article. I had read their article for the first part of the build. Those numbers are crazy. I don't know that the second phase is a better option than the first phase of their build. The stock heads with GMPP hot cam made more torque down low and solid hp at 5400. The second phase lost down low and gained over horse and torque at revs over 5500 rpm. Which is better for the street? The first or the second?
Old 07-12-2009, 04:22 PM   #5
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: LS motors
the first one is better for the street the more torque down low the better on the street that is
if i ever build one its going to be a street strip engine and i will go with the second combo
my buddy has a 6.0 in hs 01 camaro it does fine on the street with ls6 heads and intake it has a 4000 stall converter and hauls some serious a$$
it gets 17 mpg but it FI
its a 3400 pound car and runs 7.29s in the eighth
Gage
Old 07-12-2009, 04:27 PM   #6
pcmcobra
pcmcobra's Avatar
Re: LS motors
Go LS! You will NOT be disappointed! The swap is not cheap, but compared to carb swap, you got the motors free, you will be WAY ahead of the game. You will love it!
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 07-12-2009, 04:35 PM   #7
JW76
JW76's Avatar
Re: LS motors
I'd like to run the second combo with a 3.73 gear a TH400 and a 2800 stall. I have all that in the garage unused for a different setup I was going to build. Will this perform well on the street? The truck will be mostly street use with about 2 or 3 trips to the track a year. I was also contemplating adding a gear vendors overdrive unit like they did in the Hot Rod 73 pickup 6.0 build. Thanks for your help!
Old 07-12-2009, 04:49 PM   #8
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: LS motors
go for it they like to rev
378 ft lbs at 2200 is great so why not
Gage
Old 07-12-2009, 04:54 PM   #9
JW76
JW76's Avatar
Re: LS motors
Sounds good to me. The 2800 stall will help it out a little down low too, not that it will need it, but just in case. Thanks for all of your advice. Thats is probably the route I am going to take.
Old 07-12-2009, 04:55 PM   #10
JW76
JW76's Avatar
Re: LS motors
and moneyeater... I'll be in Germany in the fall for a semester. Too bad I couldn't check a 5.3 or bring it on the plane as carryon.
Old 07-12-2009, 04:59 PM   #11
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: LS motors
or you could send it to me
Gage
Old 07-12-2009, 10:43 PM   #12
3r!c84
Badass
3r!c84's Avatar
Re: LS motors
or you can give it to me
ill give u a
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
