Old 07-12-2009, 03:17 PM   #1
fdbdw
fdbdw's Avatar
edelbrock fuel pump 1721
anyone use the 1721 fuel pump, having fuel pressure issues and thinking about putting one in and was wondering if anyone has used one with a 1406 or similar carb and how well it works. I tried a pressure regulator but it got to hot and was heating up the fuel
fdbdw is offline   Reply With Quote
Old 07-12-2009, 06:39 PM   #2
c-tenkid
Re: edelbrock fuel pump 1721
I use that fuel pump on 69.It has a mild 350 with vortec heads.Probably makes somewhere around 330-350Hp.
Using 1/2 line from the fuel cell to the pump.Then 3/8 from the pump to the carb.I had it revved 6500 the other day it still was running fine.
One thing I didn't like about it is the you have to take the pump apart and "clock"The fuel ports where you want them.Pay attention to directions.
I also like it because it's made in the USA.
69 c-10 lwb,Converted to 4x4,dana 44f,12blt,4 inch lift,vortec headed 355,th350/np203 34x10.50x15 swamper tsl's
c-tenkid is offline   Reply With Quote
