Check it out
SO WHAT DO YOU THINK ?
I JUST RECENTLY FINISHED THE 2 LINK, MOUNTED THE 31GAL TANK FOR MORE CLEARENCE, AND ROUGHED IN THE BODY WORK ENOUGH FOR ITS FIRST COAT OF PRIMER. BEFORE... ![]() AFTER... ![]() ![]() ![]() ANYONE HAVE ANY IDEAS ON HOW TO GET THE FRONT A LITTLE LOWER?
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow Last edited by MI2CHEVYS; 07-08-2010 at 01:10 AM. Reason: updated pictures |
its just $$$$$
Re: Check it out
Dropmember
Re: Check it out
Yea I know i checked it out but i just got laid off and unemployment doesn't pay that good. I just might have to wait for next years tax returns.
Nice Blazer by the way!
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow |
its just $$$$$
Re: Check it out
you could always do a Z
Re: Check it out
looks good man i would do the crossmember
Happy to be here
![]() Join Date: Mar 2000
Re: Check it out
What do you have in front now?
Re: Check it out
Thanks Guys
3" DJM spindle w/ Firestone 2600 bags w/ plates up top and cups down below. I was thinking about cutting the cups just a little to maybe get an inch. Would control arms help? ![]() ![]()
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow Last edited by MI2CHEVYS; 07-08-2010 at 01:17 AM. Reason: updated pictures |
its just $$$$$
Re: Check it out
oh yeah, cut the cups for sure!
my short bus
Re: Check it out
remove you cups and cut in some 8" pipe
I used a 2.5" piece lays on crossmember and misses heater box by .5" I also have 3" belltec spindles with a upper bag plate like your I'm running 255/70/15 on a 8" rallie ![]() on my burb I went from this ![]() to this ![]() hope this helps cost me $150 for the metal and having it welded in
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
#10 | |
Re: Check it out
I wouldn't have to worry about heater box ![]()
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow Last edited by MI2CHEVYS; 07-08-2010 at 01:20 AM. |
Low & Fast!
Re: Check it out
Looks good! Cut 1" off, that is what I did but do not cut any more then that you could rub your bags..
#12 | |
Re: Check it out
By the way man love yor blazer mine will also be BLACK, that was the original color but my interior will be RED
#13 |
Re: Check it out
How much do you think I should cut off?
Do you know of anyone who has used plates on the lower control arms like these do you think these would help?
#14 |
Arrived on a Pale Horse
Re: Check it out
Doesn't that diff need a panhard bar? How will it keep from going side to side?
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
#15 |
Re: Check it out
I need to mock up the motor and trans first to get the pinion angle correct.
#16 |
Re: Check it out
could u post some pics of the 2 link,thanks
#17 |
![]() Join Date: Mar 2007
Re: Check it out
Nice job, I look forward to watching your progress. I'm just about to smooth my firewall, hopefully this weekend.
Ryan 84 ![]() My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328 |
#18 |
Re: Check it out
It's a lot of work they wernt very straight from the factory to begin with, Good Luck!
#19 |
Re: Check it out
![]() ![]() made the bars from 1.5"O.D x .25wall DOM (Expensive) Bag brackets are from suicidedoors
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!" http://s657.photobucket.com/albums/u...view=slideshow Last edited by MI2CHEVYS; 07-08-2010 at 01:25 AM. Reason: update pictures |
#20 |
its just $$$$$
Re: Check it out
do those bars have a pivot on each end?
#21 |
Re: Check it out
yes in the front of the bar it has urethane replacment bushings, or i could use stock replacement. The rear of the bar has large heim joint, i wanted to be able to adjust it if needed. I still haven't installed the suicidedoors pan hard bar. I tested the system and it travels fine without any binding
#22 |
Low & Fast!
Re: Check it out
I like that, looks simple. How are you going to run your shocks?
#23 | |
its just $$$$$
Re: Check it out
#24 |
Re: Check it out
rear set up looks great, nice work!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#25 |
Re: Check it out
Nice progress!
