07-12-2009, 05:12 PM | #1 |
Suspension parts interchange question
I wanted to run the later model (73-81 suburban) type a-arms.. The ones with actual bushings vice the metal shaft in my 66 would it be possible to swap the a-arm without swaping the whole k-member.. Just looking at the lmc catalog they look similar.. I would just have to swap the a-arm assembly.
I could see the advantage of the bushings.. I dont know if any of you have tried it vice swapping the whole k-member. Thanks |
07-12-2009, 05:44 PM | #2 |
Re: Suspension parts interchange question
Yep, they are a direct bolt in.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
07-12-2009, 06:19 PM | #3 |
Awesome!! Thanks a lot..
07-12-2009, 11:12 PM | #4 |
60-66 Nut
Just FYI, the '73-'87 C10 pickups, and the '73-'91 C10 Suburbans and Blazers all had the rubber bushings on the control arm shafts.
07-12-2009, 11:17 PM | #5 |
ya and that means you can run disk brakes up front
Smoke Tires, Not Drugs! |
07-13-2009, 02:53 PM | #6 |
The guy I bought the truck from already swapped the brakes.. I was going to get some suspension parts from the junkyard back home while I was on leave. I think its pretty weird that none of the junkyards here in Nofolk, VA have any old chevy's just 90's and up.
Definatley looking foward to getting my power steering parts Thanks for the info guys. |
