07-12-2009, 08:40 PM | #1 |
has any one build a custom frame for a blazer
i bought this tub and its going to be 2wd ive got a 4x4 frame and converted to 2wd i new that the frame horn on the passengers side was bent but i think it goes back alot further than that after puting the body on im pritty shure its might be twisted i was wondering if any one has build a frame out of 2 by 4 tubing.
07-12-2009, 09:52 PM | #2 |
Re: has any one build a custom frame for a blazer
Not that i'm aware of.
07-12-2009, 11:46 PM | #3 |
SKINNY TIRES RULE!
I believe that there are a few pickups on the board with custom frames.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
07-13-2009, 04:00 PM | #4 |
theres a guy down here with a 72
4x4 rolling frame you could convert. I might be able to get ahold of him. I wonder what a good shop would charge to repair it if is repairable? |
07-13-2009, 04:55 PM | #5 |
Not a Blazer, but you get the Idea..
http://67-72chevytrucks.com/vboard/s...d.php?t=303594
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
07-13-2009, 05:12 PM | #6 |
SKINNY TIRES RULE!
http://www.jimmeyerracing.com/ will build you a custom frame for $$$$$$.
07-13-2009, 07:19 PM | #7 |
2wd FTW!!!!
Maybe try a body shop that has a frame rack they might be able to get it back in shape.
07-14-2009, 08:24 AM | #8 |
ROCKWELL 5 TON CLUB !!
i dont think a straight frame would be that hard for a blazer.thought about it a lot when building mine,kind wished i would have done it that way.
ive got a true fisher body 71 crewcab that will probably be getting one starting this winter.
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!" MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=221935 1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS HINT:NEW NAME "K5ontheROCKS!" |
07-15-2009, 07:14 PM | #9 |
I saved this pic from a thread i found while searching its from a custom blazer
ILL TRY AND GET A LINK TO WHERE I FOUND IT
70 SWB STEPSIDE 70 BLAZER 09 challenger |
07-15-2009, 07:33 PM | #10 |
07-15-2009, 11:41 PM | #11 |
that frame is sweet my only problem is i wont to retain the back seat. i would like to straighten the stock frame but they are never really quit straight again and im going for show rig i wont every part of to look flawles as possible i no that no one will probably see it but i will.
