Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-13-2009, 01:08 AM   #1
Super73
Super73's Avatar
Home built Antiroll bar..
Ok, I'm either cheap or like to do stuff myself. Instead of buying a antiroll bar, I decided to build one.
I bought the rod ends and 1 3/4 bushings for an RV some time ago. Tonight got a chance to actually start building it. I had some 1 3/4 tube laying around as well as some 1/4 plate that I'll make the leverage arms out of. I also happen to find some tube to tie in to my rod ends. Just need to go buy 4 nuts to weld to the tube stock so I can adjust the angle of the antiroll bar.
I'll try and get some picks next time I'm goofing around with it.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-13-2009, 09:21 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Home built Antiroll bar..
We want PICTURES!!!!!!
My Nova has a suspension issue and I tear up the cheep Jeggie anti-roll bars one a season. Short of the MW splined ends I've been trying to come up with something stronger. Soooo show us what the heck your doing there super!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-13-2009, 03:22 PM   #3
AirMale
AirMale's Avatar
WE WANT PICS! you know better than to tease us.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 07-18-2009, 10:43 PM   #4
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
whats the purpose in an antirollbar on the strip
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 07-18-2009, 11:14 PM   #5
djracer
djracer's Avatar
it helps to keep the car/truck from twisting up when it leaves the starting line.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-18-2009, 11:15 PM   #6
mongoose
mongoose's Avatar
keep the truck flat... even the load between the tires
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 07-18-2009, 11:17 PM   #7
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
thanks for the info
so whats the difference between the one super73 is building and the single bar that mounts to the axle
i know what hes building ive seen them before i just didnt know what it was for
Gage
Old 07-18-2009, 11:30 PM   #8
Super73
Super73's Avatar
The factory one will twist a lot sooner, allowing for more rear axle wrap. The bigger thicker set up keeps the axle and chassis more level.
I found this very interesting..
http://stockcarproducts.com/tech1m.htm
Old 07-18-2009, 11:33 PM   #9
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
is this what your building
http://www.jegs.com/i/Jegster/550/40096/10002/-1
Gage
Old 07-18-2009, 11:34 PM   #10
mongoose
mongoose's Avatar
yup.. if you make it stiff enough you'll be able to sick a jack under one wheel and both will go up the same...
Old 07-19-2009, 12:05 AM   #11
Super73
Super73's Avatar
Originally Posted by jgh64pkup View Post
Yes and no.. The mounts I am using are very similar to factory mounts but in 1 3/4" They even mount in the factory location (with a little massaging of the factory holes). 1 3/4" tube then goen in it and I am making the leverage arms from 1/4 plate steel, cutting them out with my plasma cutter then cleaning them up with a grinder. For now I'm going to weld the leverge arms to the 1 3/4" tubing.
I'm thinking about having a set cut out with a water jet along with the 1 3/4 hole to slide the tube through then weld it up on both ends (inside and out).
Old 10-10-2009, 08:18 PM   #12
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
How did this work? Did you make it to the track with it?
Pics would be nice also.
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
Old 10-11-2009, 12:19 AM   #13
Super73
Super73's Avatar
I'll see if I can snap some pics tomorrow.. I can't get to the track right now due to finances (I'm out of work). Need to make house payments instead.
