Old 07-13-2009, 09:16 AM   #1
dznucks
dznucks's Avatar
Best way to remove stock frame rivets?
I am about to bag my '69 and i am trying to get myself ready for the install. Looking ahead to the install i am not looking forward to removing the stock frame rivets to install a CPP c-notch and CPP crop center crossmember.
This is my daily driver so I have to work fast and make sure everything goes smoothly since each phase of the install will be limited to weekends. In the past, the best way I have found to removed rivets is with a torch. But I do not have access to a torch now.
So i am wondering what other ways are there other than drilling and grinding? Would an air chisel do any good?
thanks
dznucks is offline   Reply With Quote
Old 07-13-2009, 10:27 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Best way to remove stock frame rivets?
I have found that drilling them is the fastest way for me. Use a center punch to get started, I usually start with a 3/16" drill then go with the 3/8". Also use lots of tap magic.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-13-2009, 10:37 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Look here for many popular answers- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-13-2009, 12:26 PM   #4
hAetWagon
Schlongbed MEMBER (heh)#15
hAetWagon's Avatar
There's really only so many ways to remove metal my friend. Heat,grind or cut.
I've found grinding to be fastest.
82 Chevy Blazer 4wd.RIP
1965 Chevy C10,350V8
Get it reliable,then puttin' it in the weeds..
"Old truck, all new headaches."
hAetWagon is offline   Reply With Quote
Old 07-13-2009, 12:29 PM   #5
joe231
joe231's Avatar
a good long stroke air chisel does wonders...
CHEVY ONLY
Old 07-13-2009, 12:39 PM   #6
Shane
Shane's Avatar
grind an "X" across the face of the rivet with a cut-off tool and then grab a cold chisel and a BFH.
Shane is offline   Reply With Quote
Old 07-13-2009, 01:09 PM   #7
dznucks
dznucks's Avatar
ok. thanks. i am probably going to try the drilling and grinding. i might get a good punch.
Old 07-13-2009, 03:26 PM   #8
AirMale
AirMale's Avatar
works every time!
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 07-26-2009, 10:15 PM   #9
Naterman35
Had my bump stops/ carrier bearing mount/ and exhaust hanger out in seconds.
Naterman35 is offline   Reply With Quote
Old 07-27-2009, 01:00 AM   #10
Longstep70
Junior Member
I did the X across the head with my cutoff wheel then used the air chisel. Works like a charm.
-A
Longstep70 is offline   Reply With Quote
Old 07-27-2009, 08:57 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
There is no "perfect" answer to this question. Even with a high dollar Snap-On air chisel, some of them just don't want to come out. You might need an assortment of tools to do the job.
We discovered that this weekend as my buddy Keith and I did a C-notch on his 67 project "Hazel".
Articles-
"Refining Sierra"
Old 07-28-2009, 07:14 PM   #12
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Cut an X across the head with cut off wheel, flat chisel blade in an air hammer to knock the head pieces off , and a punch in the air hammer to drive it thru , Ran into 2 or 3 out of twenty that were swedged in pretty tight, and one that I finally had to drill part way thru. Took about 1-1/2 hours and I removed right at 20 rivets.........Worked for me !
ksbrktracer is offline   Reply With Quote
