Old 07-13-2009, 12:15 PM   #1
DPowers
DPowers's Avatar
Valve cover clearance
Put my 283 back in my '66 over the weekend and I have about a 1/4 inch of clearance between the valve covers and the firewall. I have tall covers and was wondering about moving the motor mount towers forward about an inch. I want to keep the tall valve covers. The trans xmember won't be an issue because I am switching to TH350.
DPowers is offline   Reply With Quote
Old 07-13-2009, 12:18 PM   #2
EyeH8the24
EyeH8the24's Avatar
Re: Valve cover clearance
drive shaft may be an issue
DOH !!!!!!!
EyeH8the24 is offline   Reply With Quote
Old 07-13-2009, 02:20 PM   #3
DPowers
DPowers's Avatar
Shouldn't be- I am running the original two piece with carrier bearing. The distance from carrier to rearend will not change and since I am switching to auto trans- I was already going to have to adjust the shaft length from carrier to trans.
Old 07-13-2009, 04:11 PM   #4
Captainfab
60-66 Nut
Sounds like it shouldn't be a big issue to move it all at this point in your build. Just have to drill some new holes......
Old 07-13-2009, 05:04 PM   #5
DPowers
DPowers's Avatar
That's what I was thinking.
A couple of pics.
Old 07-13-2009, 05:16 PM   #6
justbad
I am running a bbc in my 66 with tall valve covers no clearanc problems you should have no problem.also you want the engine as far back as it will go to give a better weight distribution.if you move the engine to far foward it will handle like a dog also if you move the engine foward a simple cam change will turn into a engine pull. Now i will tell you clearance is a lil tight by the power brake booster and fan box but unless you are running a solid cam this should be no problem
justbad is offline   Reply With Quote
Old 07-13-2009, 10:50 PM   #7
Captainfab
60-66 Nut
Which motor mount brackets did you use? On my Suburban I made my own so I could move the engine forward a couple of inches for enough firewall clearance. I'm running the M/T covers as well.
Old 07-14-2009, 12:47 AM   #8
502tripower
502tripower's Avatar
As others have said you should not have an issue. You may want to use the later 73 up perches. I think they may give you a little better clearance but not sure.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
