Old 07-13-2009, 03:23 PM   #1
07SSSC
07SSSC's Avatar
Another fuel cell question
Summit fuel cells. I know it's been covered a million times, but I never came across a part number that everyone was using. I'm thinking it would be a good idear to order one that'll fit and seeing as how so many have gone this route maybe someone could chime in? My main priority/project is getting the tank moved soon.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline   Reply With Quote
Old 07-13-2009, 08:37 PM   #2
07SSSC
07SSSC's Avatar
Re: Another fuel cell question
ttt
anyone?
Old 07-14-2009, 11:14 AM   #3
67chevemall
67chevemall's Avatar
I just put the 16gal under my bed. Get the one with the foam and sensor or you'll regret it....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-14-2009, 11:16 AM   #4
67chevemall
http://www.summitracing.com/parts/SUM-290108/
Old 07-14-2009, 11:31 AM   #5
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yep, they fit pretty good too. Just a little trimming on the right rear crossrail.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 07-14-2009, 11:45 AM   #6
07SSSC
07SSSC's Avatar
Thanks guys, so what are you using to mount them?
Old 07-14-2009, 11:51 AM   #7
67chevemall
http://www.summitracing.com/parts/SUM-290154/
And four self tappn clading screws
Old 07-14-2009, 11:54 AM   #8
07SSSC
07SSSC's Avatar
Perfect, that'll definitely be my next purchase.
Old 07-14-2009, 12:22 PM   #9
Slick67
Sofa King Crazy!!
Slick67's Avatar
You will have to "fill up" through the bed floor, but trap doors are easy to find.
Old 07-14-2009, 01:47 PM   #10
07SSSC
07SSSC's Avatar
So did you guys run -8 all the way up, I'm thinking that's awfully big and -6 is probably more then enough plus it seems to be much more common. Anyone running from the cell to a hard line?
Oh, and did you just cap off the return line if it wasn't needed?
Old 07-14-2009, 02:03 PM   #11
Slick67
Sofa King Crazy!!
Slick67's Avatar
Not to that point as of yet. Still working on the body.
Old 07-14-2009, 02:13 PM   #12
68fixeruper
68fixeruper's Avatar
ya -8 seems huge slick 67 do u have a picture of the tank from a back view?
68fixeruper is offline   Reply With Quote
Old 07-14-2009, 02:17 PM   #13
67chevemall
yep cap the one. I got the fitting that goes to 3/8 hose and then to steel 3/8 line to the pump.
And you can mount the tank either way. There is plenty of fuel in the bowls to compensate for "take off"
Old 07-14-2009, 02:24 PM   #14
Slick67
Sofa King Crazy!!
Slick67's Avatar
Here ya go. Not to good but it should work. The left side is blocked off.
Old 07-14-2009, 02:59 PM   #15
71tahoe
71tahoe's Avatar
Any straps going on top? That thing will be pinched between the bed crossmember and the lower straps but a little more security/peace of mind might be good.
71tahoe is offline   Reply With Quote
Old 07-14-2009, 03:11 PM   #16
michael bustamante
michael bustamante's Avatar
have any of you mounted the aluminum summit tanks with the baffle and such, in this same location? (under the bad)
1967custom
michael bustamante is offline   Reply With Quote
Old 07-14-2009, 03:17 PM   #17
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yep, straps are going across the top. I will be able to bolt from the top or the bottom of the crossmember.
Old 07-15-2009, 10:13 AM   #18
07SSSC
07SSSC's Avatar
I think I've got a plan. -8 90* fitting out of the cell to a -6 reducer to a <3' piece of braided AN hose then to a 3/8" barb and rubber fuel hose. The main reason I want to use the braided line is for looks, plus I figured it would be more resistant to anything getting kicked up. I'll put a filter in the 3/8" rubber hose before going to 3/8" tubing and run that all the way up with another small piece of rubber hose going to the pump.
Thanks for all the help, I'll be sure to post up my progress once I get goin on it here in a couple months.
Old 07-15-2009, 11:21 AM   #19
michael bustamante
if youre using a mechanical pump you`ll want to mount the filter after the pump not before, when the filter before the pump gets clogged the pump works harder to get fuel prematurely wearing out the pump, and possably collapsing your rubber lines
1967custom
Old 07-15-2009, 01:22 PM   #20
07SSSC
07SSSC's Avatar
I've heard that before, problem is, I have a braided AN hose running from the pump to the carb. No where else to really put the filter. Right now it's sitting dang near on the pump with a nice little loop in the hose.
Old 10-28-2009, 11:41 PM   #21
ap2002
so does this summit fuel cell come with a sending unit that will work with a 71 c10?
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 10-30-2009, 09:45 AM   #22
67chevemall
Oh ya. Great deal for a tank at $150
Old 10-30-2009, 02:19 PM   #23
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
can i mount it with my bed on?
John
1999 Toyota Tacoma 4x4
Old 10-30-2009, 03:06 PM   #24
kelsfine69
18 Till I Die
kelsfine69's Avatar
Attachment 478496
Why is it crooked? Are the frame braces not square?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 11-04-2009, 06:52 PM   #25
VA72C10
VA72C10
VA72C10's Avatar
yes, they are crooked from the factory. so that area needs to be trimmed to fit the cell...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
