Old 07-13-2009, 04:20 PM   #1
72RK
72RK's Avatar
yet another LS swap......newb
Sorry after a two year restoration this is the first time i have posted... normally i just read what you kind folks have to say and keep my mouth/hands shut...
this board has truly been a blessing for those of us who can't get enough of these trucks....
Yet another slew of questions for you guys that have decided to go with a Gen III drivetrain for our trucks..
1) How to adapt the original tranny cooling lines to the 4l80E? My truck originally had the TH-350.
2)What is the best way to set up the fuel injection from CPP fuel tank.. only one outlet and return currently, i have talked Tanks Inc about their intank fuel pump....
72RK is offline   Reply With Quote
Old 07-13-2009, 05:50 PM   #2
tucnnuts
if they can make it so can I!
tucnnuts's Avatar
Re: yet another LS swap......newb
i would think on the trans lines you could adapt them using compression fittings maybe, or go with a newer style rad. ...maybe just reflare the newer line set to the inverted flare fittings..maybe just my two cents..
tucnnuts is offline   Reply With Quote
Old 07-13-2009, 07:00 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
NAPA usually has a good selection of tubing adapters for mating one style/size fitting to another,should solve your plumbing of the tranny issues.2.Run an auxilary tranny cooler(probably have to extend the lines for that).I don't like using "compression fittings" on the pressure from a tranny.
I would look into an electric pump(probably frame mounted) and run a fuel regulator since you already have the tank.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-13-2009, 09:06 PM   #4
boostat4500
My advise is to run a separate, large as possible, tranny cooler, if you aren't all ready, I'm not sure what these trucks came with for autos. These 4L80E's don't like heat.
Will that tank let you run an internal pump? If not just get an in-line pump. Either style, run an aftermarket reg. with it and your golden.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 07-13-2009, 09:07 PM   #5
72RK
72RK's Avatar
Thumbs up Re: yet another LS swap......newb
Thanks for the info, i will take the fittings out of the 4L80E and ease on down to NAPA and see what i can come up with....
Old 07-13-2009, 09:12 PM   #6
72RK
72RK's Avatar
I suppose i can run an aftermarket tranny cooler, i thought the one in the radiator would be sufficient. Its an aftermarket from Cheyenne man in Texas..
I planned on running an in tank fuel pump so i have the tank dropped right now... should be easy enough to make a hole and insert the Tanks.Inc pump...
Any of you guys looked at the Fuel kit available through Russell Performance...
has the Corvette regulator/filter and inline pump and quite a few feet of hose with the AN fittings.... They are kinda proud of that stuff....
Old 07-14-2009, 11:58 PM   #7
OldCreek
OldCreek's Avatar
Haven't done this yet...
but I think the compression adapter can be removed from the 4L80 case. I believe the threads are 1/4" NPT. If so, buy a 1/4" NPT sized fitting and run any type of line you want. I believe I will run a 1/4" NPT to -6AN fitting and then run a line to the cooler. (it might be a 5/16" NPT)
Also, look here for a compression fitting to -6AN that will go into the original 4L80 fitting: http://www.purechoicemotorsports.com...cat/cat135.htm
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 07-15-2009, 07:14 AM   #8
72RK
72RK's Avatar
I went to my local NAPA just yesterday and figured out that the fittings are pipe thread into the 4l80 trans case. i was surprised, figured it would have been metric...so i have some pipe-inverted flare adapters coming in today.
thanks
Old 07-15-2009, 08:04 AM   #9
Shon
I normally get a barb'd fitting and screw into the trans and run new trans lines from there, it's alot easier.
BUT for my swap, I am going to start off using the stock lines up to a point, then they are cut and flared and I will clamp lines to that.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 07-15-2009, 07:04 PM   #10
boostat4500
A word of caution on using the barbed adapters. I did that on mine and it was no good. I recently had the tranny rebuilt and they said they could tell there was a lack of fluid flow because of the non OEM fittings. Caused premature wear on the internals. Could be BS, but this shop has a great reputation in town for building high horse trannys, so I doubt it. Plus they had nothing to gain by telling me this. Just a heads up.
