07-13-2009, 08:02 PM | #1 |
Urgent help needed!
I need to know the width of the coil spring pads on a coil suspension rear housing. I'm trying to mark the rear wheelbase C/L & need to know this dimension but I don't have the rear end here @ the shop w/the frame & trailing arm stuff.
If someone has one they could measure quickly, it would be a big help. I'm looking for the dimension between the C/L of the u-bolts toward the rear of the frame.... Scot.
07-13-2009, 08:08 PM | #2 |
Re: Urgent help needed!
You need a measurement off a rearend or frame? I'm not understanding exactly.
07-13-2009, 08:09 PM | #3 | |
Mine is a 1971 1/2 ton and this is how mine is designed. Last edited by JP2120; 07-13-2009 at 08:18 PM. |
07-13-2009, 08:12 PM | #4 | |
Make sense?
07-13-2009, 08:16 PM | #5 |
Hang on..
07-13-2009, 08:21 PM | #6 |
You say U-Bolts. I thought u-bolts were used on leaf spring setup not on coil springs. What year make and model is it ?
07-13-2009, 08:25 PM | #7 |
Coil spring rears use two big honkin' u-bolts vs. lesf rears that use four smaller u-bolts. Year of the housing does not matter as the perches are the same distance apart (the 71-72 rears just had longer widths).
07-13-2009, 08:26 PM | #8 |
yes,no, maybe so?? All done from center to center
07-13-2009, 08:27 PM | #9 | |
Under Construction
There is a ubolt that mounts the rearend to the trailing arm on coil spring trucks as well.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 07-13-2009 at 08:29 PM. |
07-13-2009, 08:29 PM | #10 |
I just need the distance between the u-bolts (pass side to driver side; not the entire rear housing width).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-13-2009 at 08:30 PM. |
07-13-2009, 08:30 PM | #11 |
I gotcha now ! The forward holes on mine are 39 inches apart. Sorry for the confusion on my part
07-13-2009, 08:35 PM | #12 |
Look at the 3rd and 4th pics. Trying to show the measurement center to center of the u bolts for the front of the pad and the rear.
07-13-2009, 08:37 PM | #13 |
Ok... When we looked @ that pic, it looked like you were measuring from the backing plate. So that measurement of 42" was from the C/L of the u-bolt to the C/L of the u-bolt @ the rear of the 'perch' correct?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-13-2009 at 08:39 PM. |
07-13-2009, 08:40 PM | #14 |
Yes. Both front and rear on the mounting pad. Sorry, on the 1st pic I was trying to show there were 2 pins in the center of the pad on both sides and the u bolts on top of them so I could get a "straight across" measurement since the center section is in the way.
07-13-2009, 08:41 PM | #15 |
Yes at the rear and 39 and some change on the front side.
07-13-2009, 08:44 PM | #16 |
Under Construction
I show 42 1/4 from outside ubolt to outside ubolt on the rear of a 72 parts truck im dismantling, the rear is still installed thus the outside ubolt to outside ubolt measurement.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-13-2009, 08:45 PM | #17 |
Thank you very much. Next time there's a truck function in our area, the first few cold, frothy beverages are on me!
07-13-2009, 08:47 PM | #18 |
