Old 07-14-2009, 05:38 AM   #1
silvervic99stang
silvervic99stang's Avatar
transmission
I have a 66 chevy with a 292. it has a manual transmission 3 on the colum but i want to add a automatic. can anyone tell me what transmissions will bolt up to it i found a 700r4 for a good price will it work and what mods will i have to do to it. if it wont what will thanks
silvervic99stang is offline   Reply With Quote
Old 07-14-2009, 09:45 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: transmission
It should work. Pretty much all Chevy's use the sam bolt pattern. You will need a crossmember for an automaitc tranny. YOu can acually use the 3 speed column but not recomended. You will need a cooler. It would be best if you had the radiator cooler with a 700R4 as they generate alot of heat. You will need a way to lock up the converter, usually just a switch can do but you will have to do it manualy. I like doing it manually as I can lock up in 3rd grear when climbing mountain roads. A 3 speed auto column will work with the 700R4. A 70's van column will work for you. I used one from a mid 70's van. You can get a kit that goes from the column to the tranny to shift it. You will need a flywheel also for an automatic. I am sure I forgot something and this has been asked so many times that someone will jump in and add something I am sure.
Van upper column with a truck lower.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-14-2009, 10:27 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: transmission
You're either going to have to change your starter or at least the nosecone and you will need the two starter bolts. The standard transmission type of starter bolts to the bellhousing while the auto type bolts to the block.
Old 07-19-2009, 10:33 PM   #4
silvervic99stang
Re: transmission
i had wanted that automatic but the deal did not go thru so what are my options for a standard transmission..
Old 07-19-2009, 10:49 PM   #5
TwoFiftyShifter
Re: transmission
Do you want highway crusing or something? I love the 3 on the tree, but I know it can be rough on the highway. My 235 with 3 on the tree is good for 70mph, no more!
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 07-19-2009, 11:04 PM   #6
silvervic99stang
Re: transmission
yeah i do and i want to be able to have the shifter down to my side instead of up on the colum so what kind of transmission would work on this if anyone could give me some info it would gr8ly be appriciated..
