![]() Join Date: May 2009
Finished vintage air install
I have finished the a/c install and everything works, but when the compressor kicks on it almost kills the engine. Does it need more timing or increase the idle rpm on the carb. I have adjusted the carb idle speed but it is turning right around 1000 to 1100 rpm in order to keep it running. What's the deal? Any info well help.
Restoration Virgin!
Re: Finished vintage air install
67chevyredneck wrote up a good and thorough install here http://www.67-72chevytrucks.com/vboa...d.php?t=249479
not sure if the answer is in there, but you may want to read through it
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
I really hate wet sanding!
![]() Join Date: Dec 2008
They make a solenoid that hooks to carb linkage...when compressor kicks in, it does too and increases idle speed by pushing on the linkage (slightly opening throttle). You don't say what kind of a carb you have...but I imagine with a little hunting around you can find one and make it work...they were stock on mid 80's trucks and are adjustable by turning in or out the plunger.
sharp as a marble
![]() Join Date: Jan 2007
WESTO is correct. Might suggest you go to your local pick a part junk yard, and find one. Even if it does not work, what you will get is the bracket it mounts to, and the wiring connector. Then if it is bad go to your local parts store and give them the application for the car/truck you got it off of.
![]() Join Date: Nov 2004
Something is funky. My truck idles at 800rpm in drive and with the A/C on the truck idles just fine. I have an edelbrock 1406 and I bump the idle speed up a hair in the summer for both the hot weather and A/C, but it still idles fine at about 800 with the A/C on.
Did you have the system professionally evacuated and filled? Do you have a Q-jet? Maybe they can't handle the A/C like the others posted and need the adjuster?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-14-2009 at 05:14 PM. |
When I put air in my 74 blazer years ago I has r124a put it. It was when r134 was new and r-12 was going out. Well I had the system charged up (by a pro) and it really bogger down the engine. Well it barley lasted the summer the truck ran hot. Then the system failed. Well come to find out the system was chargeg up at too high of pressure. Once I relaced the broken parts and charged correctly it was great.
Thanks for all the input, I have an edelbrock 600(1406) I idled it up and it still seemed to bog down, I checked the vacum and had a leak, fixed the leak and idled it back down runs great now, again thanks for the input.
Cool! So was it the carb that had the vacuum leak?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
have another issue with the air, At around 3k rpm on the highway the condensor starts to howl, are the condensors only designed for so many rpm? If so i guess i'll get a bigger condensor pulley. what do ya'll think?
No idea. I have OD
![]() Vintage Air has good customer service, you can always call and ask them.
#11 | |
![]() Join Date: Dec 2006
But if it's a newer style compressor maybe those are louder at high speeds? Can you hear it easily at idle, too, and louder at 3K rpm's? |
It should have come with a Sanderson Compressor. I've never "heard" mine running.
#13 |
Yeah, the rotary design of the sanderson compressors should be quieter than the old style (67-72)piston compressors.
Got stethoscope? Maybe describe the noise?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
#14 |
Well, took her down to the shop where I bought the unit and had them look at it, test the pressure, call vintage air, and they finally conceded that it is the clutch in the compressor. They have a new one on order and will put it in on Monday. Vintage said that the more you drive the better the break in on the compressor will be, LOL. That is the first I have heard of that, anyone else hear of that. Have any of you ever had and issue with a brand new sanden compressor or vintage air, maybe i am the one in a million.
#15 |
Sorry, mines been great since new. Stuff happens though!!! I bought a brand new weed eater on sunday and realized yesterday that it had a giant crack going across the whole top of the motor
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-21-2009 at 10:43 PM. |
#16 |
Gearhead and audio junkie
I remember from somewhere when you break in a new compressor you have to turn the a/c on and off about 30 times to sit the clutch or something. On for 5 seconds off for 5 seconds while the engine is running. Helps it grab more
