67-72 to S10 swap?
Anybody here done or heard of anyone doing a 67-72 cab swap onto a mid 80s longbed S10 frame?
I do appreciate people replying but, Please don't do like the people below did and comment on why it shouldn't be done. I'm just looking for info on the swap, you can PM me with any info you have..
Robert Member 1532 Last edited by 90\87Formula; 07-15-2009 at 11:41 AM. Reason: added frame description |
![]() Join Date: Dec 2008
Re: 67-72 to S10 swap?
I doubt you will ever see that.What would you expect to gain? A lower payload? The trailing arm suspension on 67-72's are great, plenty of aftermarket support. Wy would you put a much weaker, lighter payload under a full size?
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
Registered Loser
I would think the S10 frame would be too narrow.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
track width is alot narrower
I've seen some of the swaps the guys with mid 50's trucks have done and some of the look pretty good.
To answer the above questions: Yes the frame is narrow. The 50's guys have been using wheels adapters to get the wheels out farther. I'm not worried about payload. In the 20+ years I've had the pickup, the heaviest thing I put in the back was a new washer from Sears. My old 3/4 ton Chevy van and trailer is used for any thing bigger than that. I'm thinking on the lines of my cab and a small wooden stake-bed on the back; mounted on a mid 80's long bed S10 frame. It won't be a show truck; I'm not into that type of stuff. Just an economical runaround truck or at least more economical than it is right now. Here's a link to one of the 50's swaps. http://67-72chevytrucks.com/vboard/s...d.php?t=305723
Robert Member 1532 |
#6 | |
I understand why the 50's guys do it, it is to gain independent front suspension, power disc's, upgraded safety W/ dual master cyl. Those trucks are narrower, and still need spacers as you pointed out. You already have or could have those with bolt on parts, if you want a 4 cyl engine for mileage, I would look for a Nova strait four, or something along that line? no power, but neither would a 2.8 V-6 under a full size cab. The frame is not the heavy part the cab is.
Man I to agree with not trying the swap. because unless your real energetic I see a project that doesn't get finished. If your wanting economy, Is your truck a 6 or 8 cylinder. If 8 find a good 250 straight six, and find a higher geared diff.
friend of mine is driving a 56 F100 stock 6 cylinder, 3spd trans, But he put in a 9 inch with 3:00 gears. that thing is getting close to 30 mpg's. It is sluggish on take off, but it does good when your a flying.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
BAD BOW-Silverado XST
Second gen frames are used frequently under 55-57 Chevy's. PM me an e-mail address. I have detailed frame information for the Gen II S-10s.
He asked about a later model, 67-72...Completely different situation. Wider/Heavier truck
What is the weight difference of a 55-57 CAR vs a 67-72 truck?
Frames put under tri-fives are being ued even in prostock racing. |
Hey guys. I appreciate you reading my post and replying, but I did ask for specific years of trucks and frames.
Ok, I didn't specify the frame year in the first post but did in post 5. I'll change the first post.
Robert Member 1532 Last edited by 90\87Formula; 07-15-2009 at 11:40 AM. |
