profeshinaly unimployed
bulbs
my dash is real dark while driving its like one of my bulbs for my speedo went out...but i cant see were to replace it at....so can some one help me out and tell me where the bulb is at....and im thinking about hooking up some leds for my dash lights
"having mud flaps is like asking for a smaller trophy" |
Re: bulbs
You take the whole cluster out, and the bulbs are accessible from the back side of it.
Arrived on a Pale Horse
Re: bulbs
John is right, get out your screwdriver and nut driver. Oh, and be careful not to break the PRND21 indicator spring.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
Kid's Mechanic
Re: bulbs
With as much work as it is to get to the bulbs it is a good idea to replace all the bulbs while your as it.I'm betting they are all the same age.
Re: bulbs
I plan on replacing all of mine this weekend. Anybody know what size they are?
1976 C-10 472 Cadillac Big Block |
Kid's Mechanic
Re: bulbs
GE 194's
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: bulbs
There are 13 bulbs total They are as follows.....
High beam indicator = 1 Turn signal indicators = 2 Battery warning lamp = 1 Check Engine light = 1 4WD indicator light = 1 Seat belt light = 1 Brake warning lamp = 1 Gauge illumination = 5 Some are #194's others are #168's THe 168 bulb is a bit brighter in candle power than the 194's are. I'd just replace them all with 168's and be done with it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Re: bulbs
Re: bulbs
Any issue with heat from the brighter ones? Are you running the 168's? Cause if there is no melting issues it would just make sense to run the brighter ones.
Re: bulbs
I changed all mine out to L.E.D. bulbs in the 87. Do a search, there is a thread here that describes how to take the cluster apart and chrome the back side of the metal portion. This reflects more light down and off the guage face. I also did that procedure.
Re: bulbs
I found that spraying the inside WHITE worked alot better than the chrome paint did.
Happy to be here
![]() Join Date: Mar 2000
Re: bulbs
Did you do a scientific test like those clowns on Mythbusters? Seriously, was white brighter?
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 07-14-2009 at 09:55 PM. |
#13 |
Re: bulbs
this isn't the first time i have heard white is brighter.....
#14 |
Re: bulbs
And honestly it just makes sense. If we're talking about spray bomb chrome, I can see white reflecting more light than gray.
#15 |
Re: bulbs
flat white will reflect more light then gloss white and a mirror
![]() I just replaced all of my bulbs and I wish I would of put the cleaning the cluster and painting it to thought because I can hardly see my trip odometer
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#16 | ||
Re: bulbs
I have since gone on to the white light L.E.D. bulbs that I got from www.v-leds.com pictured here. http://www.v-leds.com/Exterior-LED/C...-p4481083.html I will soon ,as funds will allow, be upgrading yet again to these installed on the inside of the front cover facing the gauges. Only in blue not white... http://www.v-leds.com/Interior-LED/D...-p6374230.html
#17 |
![]() Join Date: Apr 2009
Re: bulbs
Hey guys,
I have a stupid question , will the "LED" style bulbs dim with the switch or just go out? Desert |
#18 |
Re: bulbs
yes they WILL dim with your dimmer
![]() ![]() Last edited by joe231; 07-17-2009 at 12:01 PM. |
#19 |
Re: bulbs
I take it you only used these for the 5 gauge lights right?
BLE 'BURBAN "I have since gone on to the white light L.E.D. bulbs that I got from www.v-leds.com pictured here." how would you rate them? any nighttime pictures? Last edited by Dapper Dan; 07-17-2009 at 03:56 PM. |
#20 |
Re: bulbs
When I did my cluster, I replaced all bulbs with V-LEDS. Green for ullumination, and white behind indicators, etc. They are not as bright as a 168, so I put 168's back into the idiot lights, as I don't have true guages in that truck. Guess I should have used white paint inside instead of the chrome. There's always a next time or another truck that needs done though.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW Last edited by babyJay; 07-17-2009 at 04:16 PM. |
#21 | |
Re: bulbs
#22 | |
Re: bulbs
![]() the problem I have found with LED's is they are fairly focused, where a regular incandescent bulb will throw light out in a much wider angle so it reflects off the back of of the cluster and gives more of a glow. I tried some 1157 LED's, with 8-10 LED's in each one, in the tail light of our '66 fleet, they were disappointingly dim, the LED's all pointed towards the lens so you didn't get any reflection to light up the entire housing....I quickly changed back.... the replacement LED's made to specifically fit these trucks are a different story, there are many LED's mounted to a circuit board spread around the entire area of the lens so they do a very nice job of lighting the whole lens.....sorry if I got a bit off topic, but I'm kinda known for it ![]() quote form WIKIpedia "In contrast to other lighting technologies, LED light tends to be directional. This is a disadvantage for most general lighting applications, but can be an advantage for spot or flood lighting."
![]() ![]() Last edited by joe231; 11-02-2010 at 07:30 AM. |
#23 |
Re: bulbs
When you say chrome the back of the metal portion, are you saying the metal cover that goes on prior to the clear plexiglass piece when installing? Because on the 80's trucks i think they made them in plastic....reason i ask is i will also tackle this too....
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP [B]1972 Chevrolet K5 Blazer RIP 1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP 1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP [B] 1995 Chevrolet Tahoe 2D [B] |
#24 | |
Re: bulbs
"White" Light is made up of all the colors in the spectrum, the reason we see color is an object absorbs all the colors in the spectrum except the colors of said object...so if you are looking at a red object, the object absorbs all the colors of the spectrum except red which is reflected so we see red, if the object is blue it absorbs all the colors of the spectrum except blue which is reflected so we see blue, and so on and so on...black, gray, and white are a bit different. When "white" light hits a black object all the colors are absorbed and none are reflected, so we see black, or an absence of color. when light hits a white object all the colors are reflected and none are absorbed so we see white, so gray would be a combination of the 2. half the colors would be absorbed and half would be reflected, in a perfect gray ![]() so by this science lesson, white would be a better reflective surface as it reflects all the colors in the spectrum, so technically it reflects all the "white" light that we can see. which would be brighter than any other color...... if you doubt the science or I didn't quite explain it where it is understandable, google "why we see color" or "how we see color"
![]() ![]() Last edited by joe231; 07-18-2009 at 10:45 AM. |
#25 | |
Re: bulbs
