Old 07-14-2009, 06:15 PM   #1
Dino11
Dino11's Avatar
aftermarket fuel tank setups... filler neck pics?
hey, i bought a 72 lwb project truck. it has an aftermarket fuel tank after the axle. its a nice tank etc. the guy was planning on putting the filler neck behind the passenger rear marker light, having it hinge out. however i dont like this idea much, its neat but i dont think its very practical. i was thinking about cutting a hole through the inner bedside and having the filler neck come out in front of the tailgate. i was wondering if anyone has any pics of their setups, it would be greatly appreciated in helping me . sorry i have long posts.
Dino11 is offline   Reply With Quote
Old 07-14-2009, 08:47 PM   #2
70duramax
Re: aftermarket fuel tank setups... filler neck pics?
i was wondering about the same thing. i like the side marker light idea but do wonder how practical it really is, ie, daily driver? i was also thinking same idea but with the tail light?
70duramax is offline   Reply With Quote
Old 07-15-2009, 01:37 AM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
this is smething i've been trying to figur out too. I don't want to see it on the outside but if its in the bed and you are hauling something a long way how do you get gas. pics please.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 07-15-2009, 02:39 AM   #4
Dino11
Dino11's Avatar
I too liked the idea bout havin the taillense swing out. Its a better idea than the marker lite, more room to work with. Esp for a daily driver i thought it wouldnt b long b4 the paint chipped out around the marker lite. And that would make me sad lol.
I am glad others are tryin to figure thiz out too. I KNOW PEOPLE HAVE SLICK SETUPS - LETS GET SUM PICS!
Old 07-15-2009, 08:09 AM   #5
Mudder
Mudder's Avatar
Lots of ideas out there. Fuel doors in the bedsides are pretty popular and may be easier than the two mentioned up there. I went through the floor, and then I do have plenty of room under to make my 90. This is a marien filler that can be had for about 20 bucks.
Mudder is offline   Reply With Quote
Old 07-15-2009, 08:43 AM   #6
jbristo67
resident oilfield trash
jbristo67's Avatar
I will have mine done on the inner bedside by the end of the week and I will post some pics. It is a piece of 5 inch square tubing cut at a 45 and welded into the inner bed side over a 4 inch hole. I welded a piece of plate over the tubing and cut a hole in it to mount my filler in
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 07-15-2009, 04:41 PM   #7
harrdawg54
harrdawg54's Avatar
This is what I am looking to do to my truck....I just have one question, how did you vent it. I know the filler used is not vented and I want something clean but functional. Thanks
1969 Chevy K20 Custom Camper
350, 4sp, 33's
High on plans, Low on funds
harrdawg54 is offline   Reply With Quote
Old 07-15-2009, 04:45 PM   #8
Mudder
Mudder's Avatar
The tank I used have 2 or 3 vents coming out of it. I used one and blocked the others off. I just ran the vent hose along the filler and then put a one way valve at the end.
Old 07-15-2009, 05:49 PM   #9
john
member #16
john's Avatar
Heres another way to do it by john fabris. Some trucks also have the plumbing inside the bed with a cover like blazers.
http://67-72chevytrucks.com/vboard/s...d.php?t=211579
john is offline   Reply With Quote
Old 07-24-2009, 06:04 PM   #10
wiskydelta
wiskydelta's Avatar
Hey man, I'm doing the same thing with a steel fleetside, can you tell me how you made that 90* turn from the fill hole, this thing is kicking my ass, I'm using a suburban tank with a 1 1/4 fill hole trying to get to that Marine fill tube with a 2" hole.
Any help would be much appreciated
Thanks in advance
wiskydelta is offline   Reply With Quote
Old 07-24-2009, 07:15 PM   #11
Mudder
Mudder's Avatar
Plumbing supplies. Copper elbow that was used for steam pipes.
Old 07-24-2009, 08:01 PM   #12
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
I to am in the process of installing fuel filler in a 72 truck. I like the way Mudder did his but I have no room for filler pipe. It looks to me Mudder has no problem because he has body lift. Has this been done on a truck that is not lifted?
Here are some ideas that were suggested to me.
http://67-72chevytrucks.com/vboard/s...d.php?t=354052
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 07-24-2009, 08:46 PM   #13
big mike71
big mike71's Avatar
Here's mine, side marker fill, It's kinda a pain in the a$$ to fill for a daily driver.
big mike71 is offline   Reply With Quote
Old 07-24-2009, 10:25 PM   #14
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
Kev'sclassics- I have no body lift, and have a similar set-up with the horizontal fill tube. There's space for it , just barely, but it will work on a vehicle without a body lift. Remember a horizontal fill tube fills slow as all hell, the longer the tube, the slower it fills, so the more you can elevate the fill tube, the faster it will fill.
Also you will need some kind of vent set-up, either vented into your fill tube or on a separate vented line off the tank, etc.
I put mine behind my tail light. Hinged at the bottom, with the filler tube snaked through the opening, then through the stake pocket, then the cross sill, then to the blazer tank out back. Crappy pics are in the first link below... no need to re-post crappy pictures!
I know Yank and huggercst have done it there too, and I think quite a few other board members have also.
I hinged mine at the very bottom or the lens surround, I think yank hinged his higher, off the stake pocket. Also HuggerCST did something I didn't realize until I installed and used mine. he put LED lights in there, the OE style bulb still has that socket sticking out the back, so mine has the wiring in a kinda hinkey place. It's worked out alright, I want to re-do it with LEDs with the wiring modified to come out of the bottom of the lens
I know both of theirs were/are very cleanly done, great inspiration. Mine worked well, but was never finished before I tore the truck to the frame.lol one day......
here's a few links, read up, check em out
Should be the tail light fillers I mentioned and other cool ideas.
http://67-72chevytrucks.com/vboard/s...d.php?t=117123
http://67-72chevytrucks.com/vboard/s...d.php?t=246851
if ya search, you'll find alot more info pics etc.
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
