07-14-2009, 09:48 PM | #1 |
Pulling a Serpentine pulley off an alternator??
Ok my turn to ask a queston.
I'm trying to pull the serpentine pulley off an alternator I have and I can't get it to move. It has what appears to be a split ring wedge type of affair inside the pulley to tighten it on the shaft. The alternator is a 120 amp delco. Any suggestions or suggestions would be greatly appreciated at the moment. |
07-14-2009, 09:53 PM | #2 |
Re: Pulling a Serpentine pulley of an alternator??
I believe autozone has a lend a tool puller that could help you. They are free with a returnable deposit. Give em a call and ask.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
07-14-2009, 09:58 PM | #3 |
Ok, I can still make the two miles to the store before they close. There must be some trick to it as I haven't had any luck with normal methods.
07-14-2009, 10:35 PM | #4 |
Lemme show you something!!
There shouldn't be any internal retainer dooey-bobs. I've pulled the pulley off a couple serp. alts. and all I used was a "right-sized" gear puller and a touch of PB Blaster (after removing the 15/16 nut first). The PS Pump pulley is a whole 'nother animal altogether.....but we won't get into that!
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
07-15-2009, 07:52 AM | #5 |
Formerly- 1972SuperCheyenne
Re: Pulling a Serpentine pulley off an alternator??
The "split ring" is nothing more than a lock washer. The pulley is supposed to slide right off once nut and washer are removed. Good luck to ya.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
