It followed me home?
removing leaf springs and helper bag ?'s
I'd like to get the rear of my 1 ton down a little and I'm not sure how to do it. I already added shackles, hangers, and removed the overload and one leaf. I will be adding some helper bags so I can tow my car hauler, other trailers later.
Can I remove one more leaf and it not get too bouncy/unsafe, still 7 left in leaf pack? Approx how much will removing one leaf lower it? and which do I remove? the highest hole in the lowering shackle will lower the truck right? EDIT: after some more searching it seems the consensus is that I can remove 3 of the original 8 leafs. That sound about right?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 07-14-2009 at 10:32 PM. |
Re: removing leaf springs and helper bag ?'s
ttt
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
6.0 powered square
you should be fine with 5 leafs left and helpers
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 07-16-2009 at 12:49 AM. |
