![]() Join Date: Jul 2000
Accelerator Cable question
Does any body know if the 307 accelerator cable for a two barrel carb. is different length than 350 with 4 barrel?
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
Recovering Truck Driver
I think they are the same length, the throttle shaft bracket comes out in about the same spot on the engine. The only question I've ever had the parts people ask is V8? 4 wheel or 2 wheel? The 4x4 sit's closer to the cab than the 2 wheel.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
