Old 07-15-2009, 05:02 PM   #1
harrdawg54
harrdawg54's Avatar
Header Problems
I just installed my new front driveline and went to install the header on the drivers side and it hits the driveline. does anyone know if there is a way to "make" the header fit. Can it just be heated up and bent to the angle that works....? It needs to be moved up about an inch and out an inch.
1969 Chevy K20 Custom Camper
350, 4sp, 33's
High on plans, Low on funds
harrdawg54 is offline   Reply With Quote
Old 07-15-2009, 05:38 PM   #2
vectorit
What?
vectorit's Avatar
Re: Header Problems
What exactly did you change/install new?
Did the driver side header work prior?
Are the headers new, or purchased used?
Was there any changes to the motor mount set up?
When I ran headers on my SB K20 burb with 4spd, there was a lot of room with the frame being the tightest spot but none the less cleared just fine.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-15-2009, 08:35 PM   #3
harrdawg54
harrdawg54's Avatar
Re: Header Problems
I purchased the headers used and have not been installed prior to my engine swap. I really don't want to get new headers and would like to find a way to make these work.
350, 4sp, 33's
Old 07-17-2009, 01:17 AM   #4
harrdawg54
harrdawg54's Avatar
Re: Header Problems
Has anybody else had this problem?
350, 4sp, 33's
Old 07-17-2009, 03:29 AM   #5
72lb4x4
Re: Header Problems
Headers are a pain in the ass. I'd run manifolds dual exhaust if I had manifolds.
Bend them if they are slightly off. Get new ones if not.
72lb4x4 is offline   Reply With Quote
