Old 07-15-2009, 07:42 PM   #1
srsummers
Another frame swap question
Will my 65 SWB body fit on a 67/68 short bed frame. I found a deal on a powder coated frame.
THX
srsummers is offline   Reply With Quote
Old 07-15-2009, 09:08 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Another frame swap question
THX
Body mounts are different, and the front frame horns where the bumper bolts up are different as well.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-15-2009, 11:42 PM   #3
Captainfab
60-66 Nut
But it is not that hard to make a '67-'72 frame to work with a '60-'66 body. Just need to change a couple of cab mount brackets on the frame, and cut and weld the correct frame horns. Also the very front crossmember on the '63-'66 frames that is also the lower radiator mount, will need transfered to the new frame. The fact that the frame you found is powder coated would mean that some of the powder is going to get ruined to make it work for your '65. Using a '67-'72 frame for a '60-'66 body is much easier than trying to use a '73-'87 frame.
