Air Bags
Has anyone here bagged there Burb? I heard you need to seperate the body from the frame to notch the frame. Is that true? Any recommendations on a good Air bag kit? Thanks
SKINNY TIRES RULE!
Re: Air Bags
Welcome to the board from the other side of the state. If you check in the burb section, I think you'll find several bagged burbs. Depending on how low you plan on going will determine how much notch you need. You should be able to install the off-the-shelf c-notch kits without pulling the body off the frame.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
