conversion
what all do i need to swap a big block in a small blocks place?
its all about the +6 inches
You could just slap it in from what I hear...
But to do it properly and make it look stock, there are some parts. You'll need the motor mounts, and the towers. The engine (duh) ![]() Accesory brackets. (power steering had a remote reservoir) Possably need to go to a hugh hump on the cab floor. (all big block trucks came like this) If I left anything out...some one will add it. |
Fabricate till you "puke"
My understanding is that the BB mounts/towers are a must for manifold or header clearance. they will also mount the eng slightly rearward, for better clearance on the front & require the driveline to be shortened. I agree with Longhhorn that the best /easiest way is to have all the factory pcs. good luck....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
