Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-16-2009, 12:40 AM   #1
marc70chevy
marc70chevy's Avatar
which engine, procharged 454, 502, 0r 540
Ok, this is what i want. The most RELIABLE and somewhat inexpensive (in that order) way to get about 700-750 crank horsepower and about the same amount of torque. I plan on using this engine mostly for racing, but will still get driven on the street quite often to cruises and meets. Here are 4 options i have came up with; low compression 454, forged internals and a procharger. low compression 502 with forged internals and a procharger. high compression high revving 502. and lastly high compression high revving 540.
with the procharged set-ups i am going with meth injection as well so i can get more boost and a higher compression ration without detonation.
so i would really appreciate any advice from all of yall with much more experience than me (most of the people on here)
marc70chevy is offline   Reply With Quote
Old 07-16-2009, 02:06 AM   #2
mongoose
mongoose's Avatar
Re: which engine, procharged 454, 502, 0r 540
any big block with a prochager will net you 700... on pump gas..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 07-16-2009, 08:50 AM   #3
Ont67shortbox
High compression means race gas,or timing pulled so far back,performance suffers.You can't beat cubic inches,how about a low compression 540 with a pro charger.
Ont67shortbox is offline   Reply With Quote
Old 07-16-2009, 02:11 PM   #4
marc70chevy
well when i say high compression i'm talking about 11:1 so if i went with aluminum heads then it should be ok with 93 octane
Old 07-16-2009, 02:13 PM   #5
marc70chevy
and a procharged 540 is out of my budget
Old 07-16-2009, 03:12 PM   #6
Super73
Super73's Avatar
If you debating on the 454 or 502 both procharged, go with the 502 and gear it/stall it apropiatly.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-16-2009, 07:41 PM   #7
Wild83C10
Wild83C10's Avatar
Agree, not much of a price difference between the two and another 48 ci.
A procharged motor if built and tuned properly can be more streetable since you don't have to run big everything to get the same horse power. Also consider a methenal injection system. You can run more boost on pump gas.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 07-17-2009, 01:30 AM   #8
tomtuna1978
why not just get a 572/720 hp crate motor? its got a warranty, its reliable, and its got your 700hp. and you are gonna spent that much with a pro charger anyway !
tomtuna1978 is offline   Reply With Quote
Old 07-17-2009, 01:33 AM   #9
mongoose
mongoose's Avatar
and say hello to 4 digit power numbers!!!!!!!
Old 07-17-2009, 09:51 AM   #10
BossHogg69
motor exploder
BossHogg69's Avatar
just a thought here, but a GM ZZ502 shortblock (all forged guts, w/ 7/16 rods) gets 8.75:1 with a 118cc head. Add to that a set of CNC'd AFR 315cc heads (flows nearly 400cfm, but moderate runner size for BIG torque) with a 121cc chamber (will net about 8.5:1 on the ZZ502 shortblock with a .041" head gasket) and whatever Procharger you've already decided on. You'll probably want a custom cam to go with the blower/boost you decide to run, but this seems like pretty easy way to get 800hp/800lb-ft and not break a sweat.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-17-2009, 06:09 PM   #11
bigsnookmaster
bigsnookmaster's Avatar
12.5 to 1 compression. Forget about pump gas! They recommend race gas for these engines.
bigsnookmaster is offline   Reply With Quote
Old 07-17-2009, 11:36 PM   #12
ripdog28
ripdog28's Avatar
Some of the post look a bit off or i am misreading them. If you put a pro charger on anything, the block and heads eng should be under 9.0-1, preferably 8.5-1 compression. With the charger you will be pushing the 93 octane limits. If the engine alone is over 9.5-1/10.0-1 you will not run 93.
I personally like Bosshogg idea. have seen a shortblock 502 with AFR 305 stock(no cnc work) push 620hp with just a .550 lift cam. so add a pro charger and your talking 800+ easily.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 07-17-2009, 11:52 PM   #13
tomtuna1978
easy answer !!! ... e85 !
Old 07-18-2009, 07:48 AM   #14
Wild83C10
Wild83C10's Avatar
You can run a supercharger with 9.5:1 compression, just have to keep the boost lower. 5-6 psi? The compression ratio depends on what you want from the motor.
I believe there is more potential from a procharged BB. You can have a milder street motor and the procharger will provide all the power you want. Yes it will probably be a bit more expensive, but you will have more potential as well. You start with 700hp, then a year or two later you want more, add an intercooler run more boost, the potential goes on.
turbo=
Old 07-18-2009, 09:08 AM   #15
Alex1
Alex1's Avatar
What procharger head unit? The Vortech YSI (much cheaper and more reliable) on a 496 or so with a decent solid roller with less than 10psi will get you 900+ which means no more stock driveshaft, tranny or diff plus chassis and suspension modifications.
If you ONLY want 750hp then build a naturally aspirated egine - a cheap 496ci with worked over factory heads and a solid roller can get you that.
Alex1 is offline   Reply With Quote
