Old 07-16-2009, 09:26 AM   #1
prin
prin's Avatar
??? about drop...
OK, I have 2" drop springs in the front and a 2" block in the rear. If I add 2" spings to the rear, will the truck be level?
prin is offline   Reply With Quote
Old 07-16-2009, 09:37 AM   #2
hoss67
hoss67's Avatar
Re: ??? about drop...
Don't know if this will help. But from the factory on a c10 there is 2" difference from front to back I believe. Hope this helps.
hoss67 is offline   Reply With Quote
Old 07-16-2009, 10:30 AM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
prin the rear of your truck needs to drop 2" befofre its level, so yes your correct.
John
1999 Toyota Tacoma 4x4
Old 07-16-2009, 10:32 AM   #4
5150
C10 Club Tennessee
5150's Avatar
yes, you need to go two inches lower in the rear
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 07-16-2009, 11:33 AM   #5
68C10withA396
68C10withA396's Avatar
31" from highest point in front fender well to ground and 34" in rear fender to ground was stock according to the LMC catalog. Take your measurements and see if it'll work for you...
"Some people spend an entire life time wondering if they ever made a difference... The Marines don't have that problem."
President Ronald Reagan
'68 C10 SWB 396/350/4.11
68C10withA396 is offline   Reply With Quote
Old 07-16-2009, 12:47 PM   #6
mclairmo
Sounds like an SAT math question. You need to measure front and rear ride height and determine for yourself as every truck can be slightly different from factory specs, especially after all these years.
mclairmo is offline   Reply With Quote
Old 07-16-2009, 01:13 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Exactly. You need to judge for yourself what your truck needs. They are all a little different. Just park it somewhere and walk a ways away from it and stare at it awhile to decide for yourself.
Old 07-16-2009, 05:44 PM   #8
SpeedTriple
SpeedTriple's Avatar
FYI:
I have a 68 Longbed/Fleetside (Added weight I suppose on rear) with a 250 Inline 6 (Lighter than 350?)
I purchased 2" Drop Spindles for the front and replaced the original springs with factory stock size. Out rear with coils I purchased/installed 4" Drop Springs with shorter shocks. Without a tailgate and load I set about 1/2" to 3/4" high in the rear. Hope this makes sense
SpeedTriple is offline   Reply With Quote
Old 07-16-2009, 09:20 PM   #9
see ten
WTB this ad
see ten's Avatar
I don't doubt that LMC prints that kind of info...but those measurements are useless unless the vehicles being compared have the same size tires/wheels with identical air pressure.
see ten is offline   Reply With Quote
Old 07-17-2009, 10:29 AM   #10
68Stepbed
68Stepbed's Avatar
A 2/4 drop looks good. It may not be exactly level, but it's close.
I recommend getting 4" springs and doing away with the blocks altogether. If you ever decide to do something else later, 2" drop springs are hard to get rid of.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-17-2009, 11:18 AM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Install what you bought then measure and buy the rear springs that you need.
I agree with 68Stepbed also, but for different reasons. I would have installed 4" rear springs first, then you would have the option to bring the rear down more with the blocks and it would be a little more accurate. Keep in mind that you will probably need to install at the verry least an adjustible pan hard bar too, to recenter your rear end. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-20-2009, 04:30 PM   #12
prin
prin's Avatar
I did a dick move to the ole girl. I heated the fronts and put a 2inch block in the rear and then heated teh rear a tab. I only done this to see how I wanted the truck to sit. Well, I have recently installed 2inch fronts and the back in not what I like. Also, the back rides like crap. So, I am redoing everything the CORRECT way!
Thanks everybody!!!!
