Old 07-16-2009, 09:58 AM   #1
GR82BME
GR82BME's Avatar
Impala, Caprice, Roadmaster rear-end
Has anyone put in an impala, caprice, or roadmaster rear-end in 60-66 Chevy trucks? The reason I ask is because I see rear disc kits being sold on here that require the disc and caliper from one of these cars to go on the bracket that they are selling. I will be doing a swap before long and was wondering why not just swap out the whole axle? Are these axles factory posi?
Any information would be appreciated.
Thanks Derek
GR82BME is offline   Reply With Quote
Old 07-16-2009, 11:10 AM   #2
Oklahoma
Re: Impala, Caprice, Roadmaster rear-end
I would also like to know
Oklahoma is offline   Reply With Quote
Old 07-16-2009, 02:15 PM   #3
bigwavy
bigwavy's Avatar
I have one in my 64. Disc brakes and a posi. 5x5 bolt pattern. We are in the process of doing the rear fab work now. (Notch etc...) Cut off the old saddles and weld in new ones for the TA's. Also you will have to relocate the trac bar on certain years that have the boss on the pumpkin. I can't remember how much, but it is a little wider . I'll try to post some pics as we are mocking this up as I type this. Doug
bigwavy is offline   Reply With Quote
Old 07-16-2009, 05:40 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Really all you need are the 'crooked' axle saddles to do the swap and check to make sure your backspacing and axle width wont be an issue.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-16-2009, 08:49 PM   #5
65 on 24s
65 on 24s's Avatar
i did mine got 3.23 gears in it
65 on 24s is offline   Reply With Quote
Old 07-16-2009, 08:53 PM   #6
65 on 24s
65 on 24s's Avatar
go look at the pic on my clubs myspace pics i got pics of it. myspace.com/vcofmemphis
Old 07-17-2009, 08:10 AM   #7
bigwavy
bigwavy's Avatar
As promised here is the pic. It is about 1" wider than the stock rear. Approx 58". I still have to weld in the saddles, airbag mounts, shock tabs and track bar. Hope this helps. Go for it. Doug
Old 07-17-2009, 03:48 PM   #8
Captainfab
60-66 Nut
Where are you measuring to? The original '63-'70 truck 12 bolts measure 63 1/8" from WMS to WMS.
Old 07-17-2009, 06:13 PM   #9
bigwavy
bigwavy's Avatar
To the backing plate
Old 07-17-2009, 06:30 PM   #10
bigwavy
bigwavy's Avatar
Ok I had to go out to the shop and re-measure everything again. From where the wheel mounts it is approximately 61 inches. So I guess that makes it narrower than stock. Thanks Captain.
Old 07-18-2009, 08:41 PM   #11
GR82BME
GR82BME's Avatar
Sounds good, thanks for the info guys.
