07-16-2009, 11:44 AM | #1 |
1958 235 - Last change for parts
It's ready to be loaded for a trip to the scrap yard. Long block with pan and valve cover, water pump, distributor. Manifolds are gone. Also have 12V generator and carb. Email reddogeb@yahoo.com and tell me what you need.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-20-2009, 07:49 PM | #2 |
Re: 1958 235 - Last change for parts
Orrie,
Where are you located in idaho? I am in Lagrande Or and interested in your 235, is it a motor worth rebuilding? |
08-05-2009, 02:01 PM | #3 |
Just found this. You would have to look at it. It has been siting outside covered but with the intake off and valve cover loose. When I pulled it the cam had dropped a lobe and oil pressure had went away once (I turned it off when I saw it drop; restarted and it dropped again so I shut it off assuming the oil pump had died). I think it still turns over. I drained the water when I pulled is so there are no obvious cracks.
If you want it you can have it, I don't even want scrap value since you will have gas expense to get here. Plus I'd like to meet you! I would like to get rid of it soon, I move it to load into the trailer and it is really getting to be a sore point with my wife, I was supposed to have taken it for scrap a month ago! 208-573-1415 is my number. I will take a breaker bar out tonight and see if it budges. Patrick
