PROJECT 7DEUCE
![]() Join Date: Dec 2002
IF IT SAYS MY FILE IS TOO BIG HOW WOULD I GO ABOUT DOWNSIZING ITOR COULD SOMEONE EXPLAIN HOW TO UP LOAD PICS TO THE SITE IF YOU HAVE TIME ...THANKS LUKE
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I am not sure what you have for resizing pictures, but I use
"Camedia" and resizing is very easy on this program. I simply open file, click on image and options come up for changing the picture. One of the options is to change the pixal size and it has a down arrow and an up arrow. Arrowing down will reduce the pixal size and it works out to 378 x 276 pixals which will give you less than the 102400 limit. Submitting the picture is just a matter of following the steps on the "Browse" option. The web site has done a wonderful job setting up this feature and you should be able to make it work. Good luck! Jim |
![]() Join Date: Feb 2001
Another
program for resizing is this
http://irfanview.tuwien.ac.at/english.htm this will take you to the d/l page and its free. you will have a icon on your desktop/open pic/go to image and resize there/then save to your hard drive. |
Almost Satisfied
![]() Join Date: Mar 2002
If you have Win2000 you should have MS Photo Editor. That is an easy way to resize pics.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Back in the sticks
You can also do it in paint. Just pull up the pic, go to stretch and skew and shrink the dimensions by 50% until its within the size limits. You just do that and then save it and post it. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
If you're trying to send a .bmp file from Paint, try to save the file as a .jpg They take less space. Whatever it is, try saving it as a different type of file.
'72 Suburban 4X4 "Save the Earth, kill yourself" |
