Old 07-17-2009, 12:20 AM   #1
Rack Man
Bed to Frame Mounting Questions....
Getting ready to mount the bed back to the frame and have a couple quick questions....Its a wood bed if that makes any difference!
1. There are 10 mounting locations on the frame...but the mounting kit only has 8 bolts....Do I indeed need two more bolts or do I leave two bolts out...and if so, which two do I leave out?....Second cross sill from the front?
2. In the assembly manual it appears to show rubber pads or as they call "Cushions" that get installed between the bed and the frame....My truck was all original and there was no "cushions" installed that I recall....Do I need em or not?
Thanks in advance....
Here's a pic of the bed - Fresh outta paint!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 07-17-2009, 12:50 AM   #2
skchevota
skchevota's Avatar
Re: Bed to Frame Mounting Questions....
Second rail from the front gets no bolts. you dont need the pads, I have seen a few with them, but most dont have them.
skchevota is offline   Reply With Quote
Old 07-17-2009, 09:04 AM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
The pads were an option....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-17-2009, 09:08 AM   #4
cdowns
cdowns's Avatar
dont use pads if you like the sound of metaltometal squeaks// dont forget to install a ground strap so you're lights work properly
Old 07-17-2009, 01:09 PM   #5
BIGMAC68
BIGMAC68's Avatar
skchevota you are right about the second sill not getting bed to frame hardware. About the pads, I would use them if possible only if the body lines still met after installed.
BIGMAC68 is offline   Reply With Quote
