07-17-2009, 01:00 AM | #1 |
Types Of Axle
I just bought a 67 chevy c20 and a 69 k20. Both appear to have the same rear axle. What are they. They look like a beefed up version of a 9inch. Are they any good? What problems do people have with them? Thanks for the advice.
07-17-2009, 01:29 AM | #2 |
Re: Types Of Axle
Its an Eaton H052 axle. Really strong and dependable if maintained right.
Do a search on "Eaton H052" to get plenty of informative threads. The best are in the "Engine & Drivetrain" section.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
07-17-2009, 08:24 AM | #3 |
Certified Hobbiest
Re: Types Of Axle
ive heard the only problem, is that a dew parts for them can be pretty pricey. other than that there great axles
07-17-2009, 03:26 PM | #4 | |
Re: Types Of Axle
They are a solid heavy duty piece, with two minor flaws.
First is in gear ratio choice.....not much. The highest, most street friendly gear is 4.10. Depending upon tire size and intended use, it may not be a big deal to you. Second is in brake parts. They can be difficult to find.....and if you do, it may not be a "local" thing. You may have to do some internet searching.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
07-18-2009, 05:28 AM | #5 |
Re: Types Of Axle
Napa had every brake part I needed.The only thing I had to search to find were 32 wheel studs.It seemed like I was cleaning out the reserves of a few sources.I totally rebuilt both front and rear axles on a`72 K/20 including brake drums.
I have one I`ll be using with a Dana60 front axle in place of the 14-bolt.I`m going with disc brakes on that one.They are great for 4wds because they`re as strong as you`ll need with less bulk and weight.I`d never own a 4wd with taller gears than 4.10s. The 14-bolt is the next great GM rear axle that can`t be beat.Many swap to them with a bit of mount modification.I`d just like those who do to have the wherewithall to save the HO52s for parts for those of us who believe in these axles.I fear the day when I truly can`y feasibly run one anymore.They are a dream to work on with the drop-out diff as well as a pretty quick change of ratios if so desired.If you find a No-Spin (Detroit Locker) it`s a simple bolt-in swap if the ratio is the same.
07-18-2009, 07:05 AM | #6 |
Re: Types Of Axle
Thanks for the help. I run a 14b in my cherokee and I have never had any problems except its size. I was curious to see how many of you guys like them. Thanks again
1967 Chevy c20 1969 Chevy K20 1972 Chevy K5, LS Swap 1972 Chevy C10 1985 Jeep Cherokee SBC, sm465, np205 with 1 tons 2012 Jeep JK |
07-18-2009, 09:51 PM | #7 |
Certified Hobbiest
Re: Types Of Axle
i just recently swapped in a eaton into my jimmy, and the brakes on it are not working, so chances are NAPA will have parts that i need?
07-19-2009, 01:07 AM | #8 |
Re: Types Of Axle
I love'em too. But you can't get the drums for a 1971 3/4T 4x4 though. But if you would switch the backing plate in this case to a 2WD 3/4T or a 72 3/4T 4x4 you should be good to go.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
07-19-2009, 07:07 AM | #9 |
Re: Types Of Axle
Yeah Roger,you`re right.I remember that now.It was in the`80s that I needed drums for my`71 K/20 and I couldn`t find them.I came up with this fantastic place called Parts Jobbers that would find it if it was anywhere out there.They found my pair and told me they were 2 of the last 9 out there.They are one year only and different from 2wd.Taller and narrower.
Swapping brakes on these full-floaters is easy.I had a hard time getting the right rear brake parts for my`72 GMC K2500 with a Dana60.We finally figured out the truck had 2wd brakes from the plates out.GM did that at the factory.This truck is all original.They must have run short on parts.As long as the brakes came off a leaf spring truck it can be done.
07-19-2009, 08:57 AM | #10 |
Re: Types Of Axle
i just swapped my rear drums on my HO52 to disc i bought the ruff stuff brackets ($50) front GM calipers/hoses/lines/pads from a 3/4 1976 4x4 ($200) and put extended brake hoses
now i have same brakes front and rear on my 1972
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_- 1972 K10 4"lift 33"tires (soon to be bigger and better) 2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's |
07-19-2009, 11:13 AM | #11 |
Re: Types Of Axle
What about the front dana 44 with drum brakes. Can I just swap oe brakes off another 44 that has disc? Or where do i find brackets?
07-19-2009, 11:23 AM | #12 |
Re: Types Of Axle
find a d44 use the disc brake knuckles and spindles and everything from there out
07-19-2009, 11:45 AM | #13 |
Re: Types Of Axle
Ok thats what i figured.
07-19-2009, 04:00 PM | #14 |
Re: Types Of Axle
I forgot it was a closed knuckle. So how do i convert this type? Or just switch it out with an open knuckle?
07-25-2009, 06:36 PM | #15 |
Re: Types Of Axle
you'll need a open knuckle
07-25-2009, 07:32 PM | #16 |
Born Psycho
Re: Types Of Axle
i believe a boardmember (blackbird customs?) was making a disc conversion for the closed knuckle 44s.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
