07-17-2009, 12:48 PM | #1 |
Registerd User
Crossmember question.
I converted my 65 C20 to 5 lug but still have the orignial cross member under it. I measured a 84 c10 crossmember and it was @1" narrower than my C20 frame. I have herd that the frame rails will bend to fit by simply lowering the frame onto the member. Has anybody done this?
07-17-2009, 03:06 PM | #2 |
Re: Crossmember question.
Not the same years, but i put a '72 C10 crossmember on my '60 C10 frame and yes the frame rails had to be "pinched" in about 3/4" total to fit into the crossmember. the core support was a tight fit but it did line up with front mounts. don't know that this is much help...
since then i have hacked mine to sh@t making my own crossmember in order to go low.
"When in Rome we shall do as the Romans,...when in Hell we do shots at the bar." |
07-17-2009, 03:08 PM | #3 |
btw,....all i did to make it fit was ratchet strap the front frame horns just enuff to make room. it was simple for my C10...not sure what the differences are between the C10 and C20 frames though...good luck.
Chris
"When in Rome we shall do as the Romans,...when in Hell we do shots at the bar." Last edited by MMM...BRAINS...; 07-17-2009 at 03:08 PM. |
07-17-2009, 10:37 PM | #4 |
Registerd User
Thanks.
07-17-2009, 11:25 PM | #5 |
didn't believe me did you?
PM Captainfab, i believe he has done a few
CHEVY ONLY Last edited by joe231; 07-17-2009 at 11:27 PM. |
07-18-2009, 12:53 AM | #6 |
Happy to be here
Can you guys elaborate? I was under the impression that a 73-87 crossmember would swap in to a 63-66 frame with no trouble. Is this issue because it was a C-20?
07-18-2009, 09:55 AM | #7 |
I believe the frames are all the same (between the c-10 and c-20) but some have had issues with the frame being a bit wider or a bit narrower, not sure if it was variances in production or what exactly. I know when I pulled the cross member off of our frame to begin the frame-up the frame kinda sprung out a bit. I have heard from multiple people that they have just squeezed the frame together or used the bolts on the cross member to pull the frame out to meet the cross member. It hasn't seemed to be much of an issue since the frames are rather flexible.
CHEVY ONLY Last edited by joe231; 07-18-2009 at 09:55 AM. |
07-18-2009, 12:12 PM | #8 |
Happy to be here
Thanks Joe. Just wanted to make sure I wasn't passing along bad info next time someone asks.
07-18-2009, 12:18 PM | #9 |
CHEVY ONLY |
07-19-2009, 11:10 PM | #10 |
Registerd User
Then another question. Since I have 84 c10 spindles, steering linkage. Will 84 control arms bolt up to my 65c20 cross member? I know I'll have to get lower cross shaft cradles. I don't know if the bolt holes for the lowers are the same. I only want to do this for the bushing differance.
07-19-2009, 11:31 PM | #11 |
I have heard different things about doing the arm swap.....some say they will bolt up, some say you will have to open existing holes and some say you have to drill new holes...........
CHEVY ONLY |
