Old 07-17-2009, 02:54 PM   #1
Nova70
Nova70's Avatar
SBC to BBC
My dad worked out a deal with his buddy at work and got me a 502 block to build. It's had all the machine work done so the block is like new. Anyway, I've been doing some research but can't find the answers I'm looking for. If I get some BB engine mounts, will they bolt up in the same location/holes as the SB mounts? I've read I can use the SB mounts but I'm going to get some BB mounts because they are a bit thicker to withstand the generally higher torque with the big block. The swap won't be happening until probably next summer as I'm building the block paycheck to paycheck.
Sorry for the rambling,
.:Nova
Nova70 is offline   Reply With Quote
Old 07-17-2009, 06:38 PM   #2
JimKshortstep4x4
Re: SBC to BBC
You will need BBC engine stands as the small block stands won't work for the big block engine.
(Unless it is a 4x4).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-17-2009, 07:07 PM   #3
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
Re: SBC to BBC
4wd or 2wd? If it's a 4x4 you'll likely run into some more problems down the road when fitting the BB.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 07-17-2009, 08:50 PM   #4
kgt
Re: SBC to BBC
I pulled my oe 327 and installed a 454, used small block everything and installed 1/4 inch spacer plates between the frame stand and motor mount...so i didn't have to dent the headers....didn't know better 15 years ago and its still in there today...
kgt is offline   Reply With Quote
Old 07-17-2009, 09:55 PM   #5
Nova70
Nova70's Avatar
Re: SBC to BBC
It's 4wd with a 6" lift & 35's. I'm excited to start building this thing. Hopefully when I'm done it will have upwards of 500 of each. =)
