Old 07-17-2009, 06:50 PM   #1
itchy
5.3 67 chevy engine swap
Anyone ever done a 02 5.3 chevy engine/trans swap. Its competely hookedup except for the engine wiring harness.
I plan on using the orginal type 67 chassie/body harness. But I need 5.3 engine/trans. harness ideas. I know summit sell a intake/carb setup for that engine, but thinking the fuel injection would be better. I have seen 5.3 harnesses at the local salvage yard, but gee ! I can't need all that. Any ideas ? Thanks !
itchy is offline   Reply With Quote
Old 07-17-2009, 07:44 PM   #2
chevelle
instagram "footbraker67"
chevelle's Avatar
Re: 5.3 67 chevy engine swap
www.wait4meperformance.com They are great. they rewired my stock harness to an 8 wire hookup, easy to install harness and they tuned my computer and got rid of all the stuff i wont use on it (rear o2 sensors theft deterrant). all for 360 bucks!!!!!
1967 lwb, bigwindow, factory air (converted to Vintage Air), custom option,4.5- 6 drop, TBI injected 355, 700r4, 5 lug, daily driver.
1967 Chevelle Malibu Drag car, 355, brodix heads and intake, powerglide, 10.82 @ 123 mph
1966 chevelle malibu, Street/strip, 355, spare parts from my other chevelle, 12.82 @104 mph
1968 lwb parts truck
chevelle is offline   Reply With Quote
Old 07-17-2009, 08:25 PM   #3
killer71
killer71's Avatar
harness's are fabricated in house...
http://67-72chevytrucks.com/vboard/s...d.php?t=244448
http://67-72chevytrucks.com/vboard/s...d.php?t=269754
http://67-72chevytrucks.com/vboard/s...d.php?t=195643
http://67-72chevytrucks.com/vboard/s...d.php?t=342165
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 07-18-2009, 07:09 PM   #4
kamikazekyle05
kamikazekyle05's Avatar
You can do it yourself, go to lt1swap.com and do some reading, its pretty simple actually
kamikazekyle05 is offline   Reply With Quote
Old 07-18-2009, 08:05 PM   #5
Hart_Rod
Hart_Rod's Avatar
Just curious if you've done it and how long did it take you? Thanks.
Hart_Rod is offline   Reply With Quote
Old 07-18-2009, 10:57 PM   #6
Arad68
Trucks N Tranzams
Arad68's Avatar
I am wondering too.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 07-19-2009, 12:39 AM   #7
kamikazekyle05
I havent got my motor put together yet. So technically i havent tested my harness but it took about a full day. I did my homework ahead of time, so i had my parts on hand and had my list of wires i needed removed. But overall i would say a day to do it, that includes alot of breaks for cricks in my neck and brain overloads lol
Old 07-19-2009, 02:55 AM   #8
eagleuh1
eagleuh1's Avatar
I wired up a 96 S10 Blazer with a 2005 5.3. Kept the drive by wire for CC. Everything works using the 2005 underhood fuse box. You could go smaller fuse box, but I had so used it. I used AlldataDIY.com for wiring schematics and pinouts. My first attempt at something this major, but was worth it to learn what everything was in the system. Now just have to learn how to use my HP tuners. Good luck. Jim. Not to hard, just go slow and mark what all the wires and connectors are before opening up the snakes nest.
eagleuh1 is offline   Reply With Quote
Old 07-19-2009, 02:52 PM   #9
kamikazekyle05
I also used alldatadiy, it helps if you dont know what a certain pin is for or what it does
Old 07-19-2009, 04:16 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Classic Trucks magazine did an article about the LS-series engine installed into a '72. Check August and September issues. Yeah, the September issue is out. It has a red/black Cameo on the front and says, "Start Your Engines" beneath the CT logo.
Member Nr. 2770
Old 07-19-2009, 05:24 PM   #11
tekno62
Hey Killer - for some reason these links are not working. can you re link them of give me and idea on what to search
tekno62 is offline   Reply With Quote
Old 07-19-2009, 07:02 PM   #12
68 short step
hmmmmm,try this
http://www.67-72chevytrucks.com/vboa...d.php?t=244448
http://www.67-72chevytrucks.com/vboa...d.php?t=269754
http://www.67-72chevytrucks.com/vboa...d.php?t=342165
68 short step is offline   Reply With Quote
Old 07-20-2009, 08:37 AM   #13
Shon
agree, it can be done with some reading. if you got the fuse block it is even simpler. We have done a few jeeps and my 6.0 swap should be going mid August.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
