removing bellhousing??
how do i remove the bellhousing on my 66 chevy? i already took out the tranny and removed the bolts from the bellhousing to the block. i cant seem to get it out! any ideas?
Re: removing bellhousing??
if you removed all the bolts and it wont come off get some wd40 and a rubber mallet or use a hammer with some padding
I am a Referee of life.
There are bolts from the bellhousing to the "crossmember".It's been a while but IIRC you can get to them thru the bottom of the bellhousing.They are on either side angled up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You need to remove the sheetmetal dust shields from the lower half of the bellhousing too. Other wise the flywheel and clutch are trapped inside of the bellhousing.
#5 | |
My Carbon Footprint
That's funny......this is an easy one to miss. I just put a new Centerforce DF in my truck. I can tell you this. Sometimes your dowel pins on each side of your block which is used to help align the bell housing can cause that dude to stick on there really good. I just used a gasket scraper and a little force to work/pry it off. It was pretty easy but not something I could just do with my hands. |
Thanks guys. I will try using some WD40. The flywheel and clutch are stuck inside. Check out some pics of my truck.
