Old 07-18-2009, 05:22 AM   #1
LilTruckMan'69
'69 3/4T 2wd Need's New Rear - What Fits?
Truck had d-60 w/ 4.10's and housing and pinion are shot so I'm now sourcing a replacement.
Me and a buddy have a line on a 4x4 (80's?) w/ 4.10's that we could part out w/ each other.
He also has some 3/4 ton rears w/ 3.73's laying around.
I believe I want to stay w/ 4.10's but I'm open for suggestions. (I assume 4.10's best w/ full load and a 350 powerplant) Trucks purpose is to tow a camper, car trailer, and small 4x4 pickup.
My main question is which rears will be the best fit? Width should be ok I assume but what about spring perch size and location between the different years and body styles?
If one of those 3.73 rears has matching perches I think I will roll it under and see how it goes for now since I will not have trailer and/or camper till truck is up to par.
Thanks in advance to all who respond.
LilTruckMan'69 is offline   Reply With Quote
Old 07-18-2009, 05:41 AM   #2
hugger6933
Re: '69 3/4T 2wd Need's New Rear - What Fits?
wish you were close to me, I have a 68 3/4 ton that I'll be putting on a 1/2 ton frame. The days of this truck doing hard work and lots of towing hauling are over. Jim
hugger6933 is offline   Reply With Quote
Old 07-18-2009, 05:42 AM   #3
The only bolt-ins will be pre-73 GM Dana60s and Corporate HO52s.The`73-up 14-bolts only require spring and shock mounts moved.It`s no big deal.Keep the 4.10s.You won`t regret it.
Old 07-18-2009, 03:03 PM   #4
LilTruckMan'69
Yep. This is what I was expecting. I also figured that if I was gunna be relocating mounts I would stick w/ 4.10's. The 3.73's would have been a "lets just get her on the road cuz they fit"
Thanks for the offer there Hugger. My wife has convinced herself that a rear end out of a newer truck is better (she may be right). And if momma's happy, I'm happy. Hope your swap goes well.
Just out of curiosity, are replacement drums any cheaper for a newer rear end? I believe drums for that old axle were around 300 bones. Each.
Old 07-18-2009, 09:13 PM   #5
1969 GMC
1969 GMC's Avatar
if it is a 1 ton 73+ truck, the spring pads will be the right width, but the shock mounts will need redone, iirc
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-18-2009, 09:56 PM   #6
WorkinLonghorn
WorkinLonghorn's Avatar
Don't know about the newer ones but I just bought a set of rear drums for my D-60 at AutoZone for $67 ea.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
