07-18-2009, 01:39 PM | #1 |
profeshinaly unimployed
fuel pump
i just replaced mine like 6 months ago and not its gone bad again....what would cause this i have a sbc 400
"having mud flaps is like asking for a smaller trophy" |
07-18-2009, 11:38 PM | #2 |
Re: fuel pump
It's extremely rare for a mechanical pump to die that fast. If you've got a high mileage motor, the eccentric on the cam may have worn flat. If that's the case, you'll need a new cam or run an electric fuel pump.
07-19-2009, 09:31 AM | #3 |
Re: fuel pump
would it be the cam if it happened before like this?
07-19-2009, 09:47 AM | #4 |
Georgia Boy
Re: fuel pump
There's no telling unless you take it apart, poke. You can check the pump rod for wear, there may be a lot of trash in the tank and clogged up the pump.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi. |
07-19-2009, 09:49 AM | #5 |
Robert Olson Transport
Re: fuel pump
not to turn this thread political but if this is bought at a chain autoparts store that imports alot of junk from china, it could fail easily . I have bought these discount parts before and had three parts bad out of the box.
fuel pumps do not require a core as far as i know. take a dremel and cut the top off once you have it out of the truck and see whats going on perhaps there was a problem with the internals? Id buy one with a lifetime warranty for $40 as opposed to the $20 one that has the one year replacement on it..
07-19-2009, 08:15 PM | #6 |
Re: fuel pump
i guess ile buy another one and then if that one dont work im going electric
07-19-2009, 08:22 PM | #7 |
Re: fuel pump
I'd advise checking the faulty pump for the failure cause. If by chance the cam eccentric is gone, then other lobes are soon to follow.
07-19-2009, 08:52 PM | #8 |
the pollock
Re: fuel pump
going electric os not cheap and easy dude..
you need a pump designed for pick up.. or a prepump / main pump set up.. unless you go with an intank pump itself.. fuel pumps are nto designed to "pull" (well most arent) they are designed to push.. while submerged.. dont go cheap on yer parts dude.. even if yer bored...and broke..
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
07-19-2009, 09:37 PM | #9 |
Re: fuel pump
how do i check to see if the cam is gone cuz i just highly doubt it is the fuel pump and i know nuthens clogged cuz i can blow air through the fuel pump
07-19-2009, 10:15 PM | #10 |
the pollock
Re: fuel pump
pokes..
you need to go with THE SIMPLEST SOLUTION first... ALWAYS.. cheap pump.. possibly out.. could be the solution... seeing how there is a ton of ghetto ass PO "solutions" instead of real repirs.. i would start checking everythign before you touch.. even think about..touching or blaming the motor.. the VERY first thing i would do is test the fuel pump at the lines closest to it to see if it's even pumping fuel.. at all.. check your fuel filter for garbage... pull and check the pump see if it is still intact and functiong.. period.. when check the lines between your tank and the pump.. they can be ****ty.. and case the fuel pump to "work hard" leading to failure. Especially if you are cheap and putting crap onto your truck... my truck is ugly.. loud and well dosent always run right.. but it ALWAYS gets quality parts... and as i put quality parts/ troubleshooting and repairs into it.. all the ****ty chinese crap breaks and falls off/ fails etc.. so it all gets replaced with quality stuff.. period..... love u man.. but ya gotta start checking all options here... on everything you do... freaking out and fancy parts dont fix your problem..
07-20-2009, 10:57 AM | #12 | |
Re: fuel pump
07-20-2009, 10:59 AM | #13 |
Re: fuel pump
07-20-2009, 11:34 AM | #14 |
the pollock
Re: fuel pump
pull and chec all the lines..
you are allready doing it.. so might as well.. remember the most simple solution is almost always the right answer.. do allthe lines and check them out.. might just have a clog on the pickup side dude..
07-20-2009, 12:55 PM | #15 |
Re: fuel pump
i pulled and checked all the lines i can blow air into the tank and hear it bubble
07-20-2009, 01:25 PM | #16 |
the pollock
Re: fuel pump
what about pulling? that's the important part..
have you checkek your float ever? ever seen teh strainer or anything that is in your tank?.. just my opinion..
07-20-2009, 01:44 PM | #17 |
Re: fuel pump
well i pulled the line right next to the pump put it into a container of gas and it wouldnt even suck that up
07-20-2009, 02:25 PM | #18 |
the pollock
Re: fuel pump
well then remove the pump
and rotate the motor over a few times to see if the rod is actuating the pump itself.. if the rod is moving th epump is ****.. then you have to find out why the pump is ****ting on you (cheap parts>?)
07-20-2009, 02:40 PM | #19 |
Re: fuel pump
alright man this looks like the plan lol and i guess we will find out if its parts soon enough it may take me a little while cuz taking cair of a 1 year old and working on a truck at the same time is very difficult lol
07-20-2009, 03:31 PM | #20 |
the pollock
Re: fuel pump
wow way to whine.. ive got three.. hahaaahahahahhahah
whiner hahahhaha j/k
07-20-2009, 06:02 PM | #21 |
Re: fuel pump
well dang shure enough its a faulty fuel pump the lever had no tension to it it was just floppin around
07-20-2009, 08:58 PM | #22 |
Re: fuel pump
i HATE installing fuel pumps so so bad..its a pain in the ass...i tried installing a old one i had sitting around but it didnt work eather so i gotta go to the store tomorrow and get another one
07-20-2009, 09:15 PM | #23 |
Re: fuel pump
??rotate the motor untill the rod goes all the way up and shove the pump in and bolt it on
one of the easiest things to change out.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
07-20-2009, 09:35 PM | #24 |
Re: fuel pump
even if the motor is roted the rod always slides back down i gotta hold it up with a screw driver and then try to position the pump in
07-20-2009, 09:47 PM | #25 |
Re: fuel pump
Put a big blob of grease on the rod in the hole and that will hold it in the hole long enough to get the pump bolted on.
