07-18-2009, 03:29 PM | #1 |
Power Steering Question
I have a 67 C10 and power steering was installed by th PO. The steering box is leaking fluid from the top so I assume the seal is done. Are these seals still available or do I have to replace the whole box? I was told not to drive it because I could burn out the pump but the resevoir is full, its only leaking out of the steering box. Is it possible to unhook the belt for now so I could still drive it with manual steering or should I just leave it parked until I fix the problem? Thanks
If your not living for something, your dieing for nothing... |
07-18-2009, 04:50 PM | #2 |
Re: Power Steering Question
Changing the steering gear is easy, and the seals are available, are you sure it is not one of the hoses?
07-18-2009, 04:55 PM | #3 |
No, its not the hoses. Its leaking from the top where the steering wheel shaft enters the box. Unless there are hoses inside the box?
07-18-2009, 06:58 PM | #4 |
Is there any difference between a 2wd and 4wd power steering gear box? LMC lists them separate but they look exactly the same. And were the gear boxes the same from 73-87?
07-18-2009, 07:05 PM | #5 |
member #16
Napa has seal kits for steering boxes. 2wd and 4wd boxes are different. &3 -87 boxes changed to metric fittings somewhere around 1981, otherwise the same except tha ratio might be different.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 07-18-2009 at 07:06 PM. |
07-18-2009, 09:38 PM | #6 |
The Older Generation
I wouldn't be afraid to drive it unless the fluid is pouring out of it. Just check the fluid level often. A friend of mine has a 91 S-10 blazer that the power steering was leaking on. He bought a bottle of Lucas power steering stop leak and it cured his problem. Your mileage may vary but at 9 bucks it might be worth a try... If you try it let us know what the outcome is. LockDoc
07-18-2009, 09:58 PM | #7 |
The container on the pump is full, it steers fine when I am going at a good speed but when I slow down sometimes it gets really hard or stops completely. I think its sucking air. Could it be a loose belt? I will try the Lucas stop leak tomorrow and I will tighten the belt to see what happens. I will let you know how I make out tomorrow night. Thanks
If your not living for something, your dieing for nothing... Last edited by eastcoastcivil; 07-18-2009 at 10:00 PM. Reason: Could it be sucking air? |
07-19-2009, 07:49 PM | #8 |
So I swapped out the power steering belt and it is 100% now, picked up the Lucas power steering stop leak and I am just waiting for the fluid to go down a bit. Its maybe leaking a table spoon a day. Gonna see what happens I guess.
07-19-2009, 09:33 PM | #9 |
Champagne Taste on Beer Budget
Good luck.
That stop leak might do the trick for ya.
Coming Soon: Project 1970 Country Truck |
07-19-2009, 11:06 PM | #10 | |
LockDoc
