Old 07-18-2009, 05:13 PM   #1
35spline
35spline's Avatar
Take a look at my 1969 Blazer
Here is my 1969 Blazer's, take a look at the details:
It is currently registered, tagged and safety inspected in Texas. It is very streetable but probably better suited for the trail. It has a low mile 383 (stroked 350) motor with a mild Comp cam 254H (20" of vacuum) and World Products S/R torquer heads. Edelbrock (pn 3500) multiport EFI. A sm465 4 speed manual trans (6.5 to 1 first gear) and a NP205 (professionally gone through with all new seals) with twin stick shifter that adds 2 wheel low. Dana 44 with power disc brakes and a Detroit Locker and Warn manual hubs. It has a new power steering gear box.Tuff Country EZ ride HD 4"springs. Offroad Design 4.5" shackles, 13" travel shocks on F-250 shock mounts. The 12 bolt rear has 4.11 gears a Detroit Locker and has been moved 2" back to center in the wheel openings. The springs are 64" 1988-98 chevy 1/2 ton springs with a shackle flip and 6" DIY shackles. The rear flex is retarded and may still limited by the 12.5" travel Pro Come adjustable shocks. The rubber is 33" BFG's mud on 15X10" M/T (aluminum) wheels. The mufflers need to be re-clocked for more ground clearance.
The headlamps are 7" Cibie European code with 75/85 watt H4 bulbs wired with separate relays. These are technically not street legal but you can easily get away with them because of the sharp cutoff of the European code lights does not blind the oncoming traffic.
The body sits on all new poly bushings. It is in good shape but has it's share of dings and scratches. The only area of concern might be the rockers. There is evidence of rust bubbles (no holes) under the paint. I have not worried about this since it has not gotten any worse in my 6 years of owning the truck. The entire bed and interior has been professionally shot with black LineX bed liner. This is the high pressure high temp stuff the will not peal off. The seats are super comfortable extra wide PRP seats mounted on the original blazer brackets. It has a Pioneer in dash stereo/CD player a 3 ch amp and four 6X9 speakers in the doors. There is no hard top but is comes with a really nice complete soft top (not in the pics). I have always run with the home crafted bikini top.
Martin
35spline is offline   Reply With Quote
Old 07-18-2009, 05:18 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Take a look at my 1969 Blazer
35 spline,It's a nice truck....
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-18-2009, 07:35 PM   #3
Thealien
Thealien's Avatar
For a blazer that looks like you actually twist the suspension up a bit looks pretty straight! Nice Blazer!
Old 07-18-2009, 09:43 PM   #4
clos69
Its Topless Season!!!!
clos69's Avatar
Nice blazer.....
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 07-18-2009, 10:31 PM   #5
Very nice looking ride!
Old 07-18-2009, 11:43 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
good lookin K/5 there.
Is that a first gen Firebird I see in the background?
Old 07-19-2009, 12:03 AM   #7
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Your Blazer is nice. I am prity sure I have seen it at Auto Zone in Wylie. I work there part time.
LOW DOUGH is offline   Reply With Quote
Old 07-19-2009, 12:24 PM   #8
35spline
35spline's Avatar
Probably so. I have had some bad luck with the Duralast Gold batteries. AZ tested my alt (good) when I brought the last one back for replacement.
Old 07-20-2009, 10:55 PM   #9
35spline
35spline's Avatar
Longhorn,
Good spot on the first gen. It is a 68 Camaro
Old 07-21-2009, 08:44 AM   #10
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
are you still having trouble with your battery?
Old 07-21-2009, 08:41 PM   #11
35spline
35spline's Avatar
Red face Re: Take a look at my 1969 Blazer
I think it is OK now. I went through two in two years before that.
