07-18-2009, 08:28 PM | #1 |
68 carb help
68 c-10
straight 6 250 roch mono-jet i need to replace my carb which has a manual choke with a new atomatic choke can i buy this at my local autoparts store and what do i ask for thanks for any info you can help with |
07-19-2009, 12:42 AM | #2 |
I am a Referee of life.
Re: 68 carb help
Why do you need to replace the carb?If the manual choke is hooked up and adjusted right it should work fine.If the carb needs rebuilt then they are simple enough to do.If the carb body is warped then I feel sorry for you since they seem to be hard to find.
Let us know why you think it needs to be replaced with an automatic choke and I'm sure someone has dealt with it before.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
07-19-2009, 01:34 AM | #3 |
Just Not Low Enough!
Re: 68 carb help
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
07-23-2009, 06:13 PM | #4 |
Re: 68 carb help
thanks for replying guys
here is the story i rebuild the carb twice the linkage got a little bent and was straighten out the slide got bent in the carb or plumger rod this all got worse as my bracket for the choke wire stoped holding sucure and wouldn't allow the choke cable to slide freely it also was just about out of lenght. my neighbor tried to fix it and ripped out the old cable and replaced with a longer one. in the process he had to elimanate the fixturers for the pull choke and know looks like **** i guess im just fed up over all i guess the carb works. to top it off when i was attaching the choke wire i lost the little gold tub the wirer slides into |
07-23-2009, 06:15 PM | #5 |
Re: 68 carb help
sorry it takes so long to reply i only get to the comp maybe once a week
07-23-2009, 06:20 PM | #6 |
Re: 68 carb help
also there is a part that broke off and is hanging by a wire
it is from around the carb round about 2 inchees and maybe 3 inches long a rod sticks out that looks like a plunger iwas having some stalling problems before the choke problems would this have anything to do with that this truck is my daily driver and i've been so upset i don't want to work on it |
07-23-2009, 06:34 PM | #7 |
Re: 68 carb help
i feel the pain, my carb is giving me probs. Its a monjet as well. I need the inlet nut that the gas line screws into. Hope you get it working. I have seen in the LMC catalog some chokes you can order. Maybe you should look at them.
Learning as I go! ------------------------------------- |
07-23-2009, 06:45 PM | #8 |
Re: 68 carb help
I did quite a bit of searching before I decided to rebuild mine.I had the same problem as jsmithbm.The best advice I can give you is to check with the local speed shop(if you have one)or maybe attend a swap meet.Someone there may know a carb pro to hook you up with.I looked for a carb for about a week and found one listed (I think it was "Champion") but when I called they did not have one in stock and didn't really know when they would get one.There are lots of members here that have swapped out 6 cyl for a 350 and one of them may have one.Check the for sale ads in the classifieds.The other option is to look for a old school wrecking yard with one of these trucks in it.I'm a big fan of the 6 so I really wish I could help more.There may be someone with better advice over on "Inlinersinternational.com"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 07-23-2009 at 06:46 PM. |
07-23-2009, 07:15 PM | #9 |
Re: 68 carb help
Try to find a local carb rebuilder that can exchange yours with one he may have or maybe he can repair yours. The older shops often have old carbs and parts lying around that are no longer being produced. Pick a part may also be a good source. Try Ebay, too.
07-26-2009, 09:48 PM | #10 |
Re: 68 carb help
jsmithbm
i needed the same nut also i found one at a local napa dealer |
07-26-2009, 09:51 PM | #11 |
Re: 68 carb help
i never called them, i found one at summit racing but it was a hair to big, i will try napa. thanks
joel
