Old 07-18-2009, 10:36 PM   #1
andrewt2
andrewt2's Avatar
Started working on my s10 frame swap today!
As the title says started working on my 1948 gmc truck to s10 swap today. i wanted to get the truck as low as possible so i decided not to raise it off the frame at all. I drilled out the rivets on the factory 1948 mounts and intend to weld them to the s10 rails. the cab is sitting where it needs to be and the front clip was mounted today. My s10 is a short bed so i will have to shorten my bed a bit to get the rear wheels center in the wheel well. the bed is just sitting on there now for easier storage but here are a few pictures!
andrewt2 is offline   Reply With Quote
Old 07-19-2009, 08:14 AM   #2
IL boy
IL boy's Avatar
Re: Started working on my s10 frame swap today!
looks good sitting low like that. are you adding a tranny hump to get the body to sit on the frame?
55 1st Series 5 window, getting an s10 frame and 350 sbc
Keeping it LOUD and ROUGH - just like BOONEMAN
IL boy is offline   Reply With Quote
Old 07-19-2009, 11:16 AM   #3
andrewt2
andrewt2's Avatar
to sit on the frame like i have it i had to remove the stock s10 tank. and will have to cut and build a tranny hump and a complete tunnel for my drive shaft. the s10 frame is at stock height. my plan is to putt a little bit bigger tires on it to keep it off the ground for driveability
Old 07-19-2009, 09:57 PM   #4
Lextech
Lextech's Avatar
Are you sure the cab and front end are where you want them? The front tire seems awfully far back. Instead of shortening the bed you could rework the rear suspension to get the rear wheels further back.
Jeff
Lextech is offline   Reply With Quote
Old 07-19-2009, 10:20 PM   #5
andrewt2
andrewt2's Avatar
the front is pretty much how i want it. but the rear will still need some work i dont plan on doing any suspension and im kind of building a low budget hot rod out of this one so a shorted bed will fit the bill perfectly.
