Old 01-07-2003, 11:05 AM   #1
Frank_Zeller
Frank_Zeller's Avatar
FYI Headers for Lowered Trucks
Been wanting to replace the old full length Hedmans with 3/4 lenght headers. Did not want to spend the 220 for the Dynomax WLK-86118 3/4 length coated header. Found the painted version WLK-85118 for 109 at summit
the specs
Chevrolet: 1964-88 283-400, Chevelle/Malibu/El Camino, 1967-81 Camaro, 1 1/2 in. primary tubes, 2 1/2 in. collectors, painted, shorty header
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 01-07-2003, 01:47 PM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
Did you notice any difference in power vs. the long tube headers? I'd just as soon avoid any clearance issues since I have slammed my front crossmember on the occasional big bump and I've only dropped it 2.5" / 4".
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 01-07-2003, 03:40 PM   #3
Frank_Zeller
Have not installed them yet......The Headmans have 1-5/8 primary with 3 inch collector vs. 1-1/2 primary with 2.5 inch collector.
This is from the Dynomax site
Primary Tube Length
Determines torque above or below the peak horsepower RPM point. Shorter tubes add torque above the peak RPM point and reduce torque below. Longer tubes add torque below the peak RPM point and reduce torque above it.
Primary Tube Diameter
Determines peak horsepower RPM point. Use small diameter tubes on small CID engines to produce mid-to-high-RPM torque. Use large diameter on large CID engines to produce mid-to-high-RPM torque. If in doubt, use smaller diameter tubes
Austin-Texas
Old 01-09-2003, 05:33 AM   #4
baggedondubs67
Question
sorry this might sound stupied but my truck is in the shop getting bagged and I need shorty style headers you think these will fit my 67 SWB?
baggedondubs67 is offline   Reply With Quote
Old 01-09-2003, 10:00 AM   #5
Frank_Zeller
Do a search on "Headers for Lowered Trucks" on the board.
Austin-Texas
