Old 07-19-2009, 04:09 PM   #1
chevymotocross
chevymotocross's Avatar
Brake drum won't come off!
Guys, I need help, I need this truck for the week! I went to check my rear shoes today. The right side drum wasn't coming off, so I attempted to turn the star wheel. I turned it the wrong way (tightened). So I went to go the other way and the star wheel adjuster won't move at all and I rounded it off.
How can I get this drum off?!
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 07-19-2009, 04:32 PM   #2
billnorman
Re: Brake drum won't come off!
Wowzers. I'd make the edge of whatever you are adjusting SQUARE like with a grinder, like a new screwdriver. Then I would make SURE you are turning it the right way. You must remember I think the left and right wheels adjust in an opposite manner. Get sure you are turning it correctly, and if you have to, use your tool as a chisel and hammer it until you get it loose. the important thing is to adjust it in the correct direction.
billnorman is offline   Reply With Quote
Old 07-19-2009, 05:09 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Get a bigger hammer.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-19-2009, 07:22 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
cmc,
You need to go into the adjuster hole with a small screwdriver and push the adjuster lever off the adjuster wheel, While holding this lever off the wheel slide a larger screwdriver (brake spoon) next to the small one and back it off.
A little penetrating oil sprayed through the hole onto the adjuster threads would surely help, It can be cleaned off with brake cleaner once the drum is off.
Good Luck
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 07-19-2009, 07:31 PM   #5
chevymotocross
Got it off! Thanks guys
Old 07-20-2009, 05:21 PM   #6
billnorman
Restrorob sent in a cool picture. I see tie rods in his photo, but, of course it's not a rear wheel. I can't remember when I had a front wheel self adjuster, but there it is. I guess I have had disc brakes too long. I forgot about moving the ratchet lever up. Good hint Restorob.
