07-19-2009, 04:39 PM | #1 |
What headers work well on 4x4's
Hi i have a 71' k20 with a 350 and a 4 speed. Which headers are you guys running with this setup. thanks.
-1971 K20 350/sm465 -2004 1500 |
07-19-2009, 09:03 PM | #2 |
the pollock
Re: What headers work well on 4x4's
im running full length headers, although it was a pain to get the tubing in correctly (without hitting the t case etc..) it works for me..
ive heard that shortys are better (mroe room for your bend) but.. im not experienced with them..
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
07-19-2009, 09:50 PM | #3 |
60-66 Nut
The Headman #69230's are supposed (Ihaven't bought mine yet) to be the best for a 4x. They don't hit the shackle bolt on the pass side. That part number is for the plain black ones, they are available in the Elite series also.
07-19-2009, 10:20 PM | #4 |
Im running headmen headers... Remember... pain to get to the drivers side rear SPark plug with them... haha.. im not sure what number that is
07-20-2009, 06:01 AM | #5 |
You need to look at the driver side header and see if the rear tube goes straight down or slightly forward.Then you`re fine for a manual transmission.Remember,you can always relocate the z-bar mount on the frame back a little if it`s too tight.i`ve cut one arm off and rewelded to clear headers before.IMO,anything less than a full length header is a waste of time.In 2wd automatics the angled 3/4 length car type are worthy.Doug`s Tri-Ys work and so do Headman Elites.I`ve been told Hooker Super Comps work,too.
07-20-2009, 11:43 AM | #6 |
I have NOS hooker super comps from back in 1977 that were made for 67-72 chevy GMC truck/blazer/burb AT or Manual I want to get them ceramic coated before installing them.
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 Last edited by teamradrz1; 07-20-2009 at 11:44 AM. |
07-20-2009, 12:50 PM | #7 |
urban fourwheelin
I've got hooker headers on my blazer. It's an auto. No real fitment issues. My buddies 71 k20 4-speed has tons of fitment issues. the collector flange is very close to the shackle and the clutch linkage had to be modified to fit.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
07-20-2009, 06:13 PM | #8 |
thanks for the input guys. Im glad i didn't just buy some $90 summit headers.
07-20-2009, 06:18 PM | #9 |
Has anyone had any luck with block huggers. I have a set of cracked ram horns and kinda want to go headers.
07-20-2009, 08:50 PM | #10 |
IMO block huggers are a waste of time.Might as well run manifolds.Block huggers were concieved for street rods running V8s in narrow`30s car frames.
07-22-2009, 06:51 PM | #11 |
Better late than never??
I've got Hedman 69830's on my K2500 (with an auto). Same as the 69280's but coated etc I believe. Fit is great, tighter against the chassis on the drivers side. Clears the shackle bolt on the passenger side by 1/2". Don't know how they would go with a manual.
1972 K2500 Long Box 400/350 |
07-22-2009, 07:56 PM | #12 |
Cool the pics are a great help. Is there anyone with a 4 speed with pictures?
07-22-2009, 07:59 PM | #13 |
it sure is tempting to get a set of summit headers and and hack as necessary.
07-23-2009, 12:29 AM | #14 | |
60-66 Nut
Do you happen to have a pic from the side of the drivers side so we can see if there is clearence for a bellcrank for a manual trans?
07-23-2009, 04:14 AM | #15 |
Quite a bit of chassis in the way. Let me know if there is anything more specific you want me to take photo's of or some measurements you want me to take.
1972 K2500 Long Box 400/350 Last edited by Billhilly; 07-23-2009 at 04:17 AM. |
07-23-2009, 10:42 PM | #16 |
60-66 Nut
Thanks very much for the pics. What I was mainly after was a shot like this pic but up at the level of the top of the frame.
I'm just curious to see (I'm sure others are as well) if these headers will work with a manual trans. The main item of concern is the #7 exhaust tube and if it curves far enough forward to clear the bellcrank. In the pics you've posted so far, it appears as they will work, but one more pic might remove the doubt.....that is if you don't mind Are you familar with where the bellcrank goes with a manual trans?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 07-23-2009 at 10:44 PM. |
07-24-2009, 05:45 AM | #17 |
Unfortunately I don't know what the bellcrank looks like. Fat lot of use I am! Got a picture?
These shot's any better?
07-24-2009, 02:07 PM | #18 |
When I had a 350 & manual linkage I ran Hedmen. First set was the cheeper ones and after a while they warped and even with two gaskets I could not get them to not leak. The pic above is Hedmen Elite series = MUCH better, way thick flanges to prevent warping. In the pic above look closly at the frame bracket the Z-bar mounts too. I had to drill a hole just to the right of the factory location to move the Z-bar towards the firewal just a bit. This did not affect the Z-bar's function and my manual linkage worked fine. I would go with Hedmen Elites, the collectors clear and they tuck up nice and high away from trail obsiticales. I have a 454 now and run Thorley's with Hydrolic clutch so no linkage to worry about.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
07-24-2009, 10:30 PM | #19 | ||
60-66 Nut
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-13-2010 at 03:05 AM. |
