Old 07-19-2009, 08:40 PM   #1
orangek5
orangek5's Avatar
reverse taillight?
My truck came with colume shift and PO put an auto floor shifter in it. Now my ?. where is the switch/mechanism that activates the reverse lights when the truck is in reverse located at? in the colume? on the transmission? or somewhere else?
Help
And thanks in advance
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 07-19-2009, 08:46 PM   #2
vectorit
What?
vectorit's Avatar
Re: reverse taillight?
I'd bet it's on the trans.
What kind of trans is it BTW?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-20-2009, 05:12 AM   #3
JimKshortstep4x4
The three speed trucks have the backup light switch on the column in the same location as the column shift automatics. The switch is different as it does not have the neutral safety switch built in.
Take a look on top of the column close to the firewall to see if the switch or wiring is there.
I don't know if all three speed manual trucks came with backup lights as I believe it may have been an option.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-20-2009, 04:10 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
they were standard on all 04 and 34 models 67 - 72
Old 07-20-2009, 04:19 PM   #5
orangek5
orangek5's Avatar
Use to be a manual Transmission, cluch pedal has been cut off just below the pivit point. Now it has a TH350 with floor shift without any Safety-Lock-Outs. Any suggestions on how to make them work while truck is in reverse would be appreciated.
1970 Jimmy 4x4 IL6
1971 SWB 327ci v8
