07-19-2009, 11:04 PM | #1 |
built a new engine,,new times
Never fast enuf. I pulled out my 6.0L that I finally got to 11.80's. Found a deal on a blown up 6.2 escalade engine. I got a rotating asembly to make it a 418 and used the cnc ported L92 and cam from tsp.
I got it running on monday and drove it around a few days to make sure everything was fine. Track time friday night was impressive, I still need to do some tuning and fine tune the takeoff and shift points. Best time friday 1.63 60ft 7.03 at 97 1/8 mile 11.16 at 117 1/4. This is still fun to drive around town and has good street manners. |
07-20-2009, 01:21 AM | #2 |
Re: built a new engine,,new times
Congrats!! I think you took the #1 spot on this site for the fastest Gen3/4 motor on the site. You got me by .02 and 2 mph.. But, don't get used to it, I've lost 300+ lbs and probably picked up 20-30hp along with a drastic gear change. You might beat me in to the 10's as well. but I'll be working for that #1 spot next time at the track!!
Was the 6.0 a factory shortblock? What are you doing with it?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
07-20-2009, 09:03 PM | #3 |
Those are some nice #s!
Would you care to share any more info on your combo? I'm thinking that my next project engine will be an LS-based engine, and I would like to learn as much about these as I can. Again, congrats on the good numbers!!
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
07-20-2009, 10:26 PM | #4 |
Thats pretty impressive but wheres the video????
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
07-21-2009, 02:35 PM | #5 | |
The 6.0 was a factory shortblock except with arp rod bolts and cam. I am thinking about selling it to recoupe some the expense of the new engine. We are going back to the track weekend after next maybe it will get a high 10 this time. |
07-21-2009, 02:41 PM | #6 |
Not really a whole lot to it. 6.2L with 418 rotating assembly, 11.1 cr, cnc ported l92, custom hydralic roller from texas speed (don't remember specs exactly 650/660 lift 240/250 @ 50),, proform 950, turbo 400, ptc 3600 convertor, 4.10 gears, 315/60/15 drag radials.
07-21-2009, 02:42 PM | #7 |
02-10-2010, 12:44 PM | #8 |
I can't believe I missed this thread. That's awesome.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
02-10-2010, 01:05 PM | #9 |
nice combo. still amazing how much power a well planned LS can make.
i would guess a 100shot to pick you up 6-7 tenths if you hit it out of the gate |
02-10-2010, 03:16 PM | #10 |
I got it down to 10.90's at 119 on motor. The 100 shot got me a 10.50 at 125, but I didn't hit it untill after the 60ft. You are probably right though, I was guessing 6 tenths.
68 chevy truck ls3, 418ci, pump gas 10.81@121.8 all motor. 1.47 60ft 70 suburban 350 tbi swap, 700r4, work in progress |
02-10-2010, 04:25 PM | #11 |
Bada$$ bro
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
02-10-2010, 09:22 PM | #12 |
Real impressive numbers to have street manners!
02-11-2010, 10:34 AM | #13 |
On a budget like Fred Sanford
Very nice! Must have some nice 60ft's, that's a good ET for 119mph!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 02-11-2010 at 10:35 AM. |
02-11-2010, 11:22 AM | #14 |
Thanks guys.
It gets decent 60fts. 1.56-7. I wish it got as good as my friends 72 truck. I built him a 406 and it 60fts like crazy (1.49-51) but runs 11.30-40's at 113. It is also stock suspension but we are fighting wheel hop at the track. It breaks gears and posi too much.
02-11-2010, 11:48 PM | #15 |
Mean Green
Another reason to Build a coil over valve cover engine. That thing has to put out around 650-700 HP. With a hyd. roller even. Unless the truck weighs 3-3200lbs
Congrats on the ET and other times. Those Ls based engines sound so evil running down the track.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
02-12-2010, 03:59 AM | #16 |
nice times ! i sooooo wanna build an ls ! u got any pics of your set up ?
02-12-2010, 11:04 AM | #17 |
subbing!!
I am taking my 6.0 swapped 71 on 3/20 to local 1/8th mile to see what it does. Not expecting too much on street tires but it will be fun. Going to have 3.73/posi unit installed before then. If there are not pictures in this thread I would like to see some, can not see much on the network I am currently on.... BUT, is there a Gen3/4 1/4 mile list??? I like seeing the list and shooting for spots....already did the bolt on LT1 in a 97Z28 (11.80 @ 113+) and I think it would be fun to see where I can take this old truck without loosing my mind HA!!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
02-12-2010, 12:35 PM | #18 |
there is a b-body list like that as well. kinda neat to see where peeps are running.
02-12-2010, 12:35 PM | #19 |
02-12-2010, 08:59 PM | #20 |
Nice times. I wish i had another truck to put an ls in. But the wife will kill me...What fuel tank, pump and regulator do you have?
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
02-12-2010, 11:04 PM | #21 |
quik fuel holley look-a-like, and holley reg.
02-15-2010, 01:27 AM | #22 |
Ready to go fast!!
fast 68... i believe i saw your truck in a mag???
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
02-15-2010, 11:31 AM | #23 |
Yes it was in carcraft.
02-16-2010, 07:06 PM | #24 |
Your truck is just awesome man. I hope I can get mine to run as good as yours soon. I have a combo pretty close to your old one, but my truck is a complete turd so far. I'm so disappointed with my combo that I'm now considering parting it out and starting over with a different truck and a BBC. I'm looking for low 11's but with the way it ran the last few times I drove it, I'd be lucky to run in the 14's. Anyway, I'm looking forward to seeing a video of your truck.
02-17-2010, 03:13 PM | #25 |
1fast68.. where you @ in east texas?
Shawn
Shawn 85 SWB 7.39 @ 93 Best so far with 0 tuning Lesson in life: Never fry bacon naked! |
