Old 07-20-2009, 09:32 AM   #1
6600DURAMAX
6600DURAMAX's Avatar
Transmission Temp Probe??
Looking to buy an aluminum trans pan for my TH400, can I mount the transmission temp probe in the drain plug hole? Or should the temp probe be mounted in line?
I plan on buying a AutoMeter Guage
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 07-21-2009, 09:57 AM   #2
6600DURAMAX
Re: Transmission Temp Probe??
TTT
No one monitors tranny temp???????
Old 07-21-2009, 12:26 PM   #3
mrein3
mrein3's Avatar
I have a th350. I took a pipe plug out of the case just above the pan and stuck the sensor in there. Not a perfect solution but it works for me.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-21-2009, 12:40 PM   #4
mclairmo
I would be concerned about it getting knocked out or pulling out somehow and all my fluid draining out. Also, to drain the pan, you have to remove the probe, which might weaken the probe and its associated wiring every time you remove it. Just a thought.
mclairmo is offline   Reply With Quote
Old 07-21-2009, 12:50 PM   #5
6600DURAMAX
Wonder if the TH400 has a plug in the side of the housing that the probe can go into???
Old 07-21-2009, 12:57 PM   #6
6772owner
Gearhead
6772owner's Avatar
I would try to find the pressure test port (should be an 1/8" NPT) for the trans temp, the drain plug would probably work, but I would be concerned as stated above. Also Im not sure of the accuracy of the temp in the bottom of the pan, seems it would be cooler than the rest of the trans to me. You can also weld a bung into the side of the pan, just make sure the probe doesnt "bottom out" on the internals of trans or it will just be maxed out all the time. Autometer sells a specific "short" sender for this purpose. Good luck with your quest.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 07-21-2009, 02:47 PM   #7
turp mcspray
turp mcspray's Avatar
On my th350 I bought a fitting that would accept the temp probe end and welded it to the side of the pan, (after drilling a hole of course) I bought an Auto meter trans temp gauge to match my other gauges. A regular temp gauge will work as well. Same thing anyway. Find an aluminum fitting and have it welded to your pan. I bought my fitting from a place that services pumps. (air pumps/compressors, gas pumps, well pumps, etc.)
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
