Old 07-20-2009, 03:34 PM   #1
80chevyshortbox
80chevyshortbox's Avatar
steering column (help)
hey i am working on my steering column and i am trying to take out my shifter stick thing and my signal light stick thing and i cant figure out how to take them out. if any one can tell me how to get them out and also what i should not do when taking this out. i just dont want to mess up my column.
thanks.
80chevyshortbox is offline   Reply With Quote
Old 07-20-2009, 03:50 PM   #2
Joe R
Re: steering column (help)
The column shifter handle comes out by removing the pin that it pivots on. The turn signal level is a little more complicated. You have to take off the steering wheel and lock cap to get access to the turn signal switch assembly. Once you can see the assembly you will see the screw holding the level in place.
Joe R is offline   Reply With Quote
Old 07-20-2009, 03:55 PM   #3
80chevyshortbox
k and whats the best way to take out that pin for the shifter.
Old 07-20-2009, 04:43 PM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
is to tap it out with a punch
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-20-2009, 05:02 PM   #5
80chevyshortbox
ok thanks for the help i figured it out.
Old 07-20-2009, 09:04 PM   #6
keith61760
keith61760's Avatar
I never could get the shifter pin out. When I replaced the steering column yesterday, that stupid pin fell right out once the column was out of the truck.
keith61760 is offline   Reply With Quote
Old 07-20-2009, 09:31 PM   #7
asphaltburner
asphaltburner's Avatar
FYI:
http://67-72chevytrucks.com/vboard/s...00#post3225400
Just in case there's anything to pass on from it,...
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
