Old 07-20-2009, 03:34 PM   #1
espree
Electrical Help
Need help guys...I have a 79 K% 2 wheel drive and recently swapped my front clip for a 91 Suburban clip. My questions is the headlight wiring. The 91 clip still has all the wiring in placs as well as the harness. Anybody have any ideas on the best way to do this without changing out the firewall connections? Any wiring diagrams to make sure all lights are connected properly? Thanks
espree is offline   Reply With Quote
Old 07-20-2009, 04:51 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Electrical Help
Has anyone done this before?
tvblazer78 is offline   Reply With Quote
Old 07-20-2009, 05:12 PM   #3
fixit-p
fixit-p's Avatar
Re: Electrical Help
If I were going to do this I would get some metri pak or weather pack connectors and just connect the two harnesses maybe at the fender or radiator support here are a couple of diagrams I got from autozone.com. The color codes appear to be the same, hope this helps.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-20-2009, 08:43 PM   #4
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Electrical Help
That's what I would do, cut it at the fenders or plugs.. Thanks for the info fixit-p..
Old 07-20-2009, 11:23 PM   #5
espree
Re: Electrical Help
Thanks guys....the diagram is just what I needed.
