07-20-2009, 05:34 PM | #1 |
Wood Bed
I am redoing my 68 and it has a steel floor that is pretty much gone because some has thrown heavy stuff in the back and caused it to be wavy. So i was thinking of doing a wood bed and i was wondering has anyone attempted to cut there own wood and if so what kinda tools are required.
07-20-2009, 05:46 PM | #2 | |
Re: Wood Bed
You can use a router to cut out the wheel openings or a jig saw. We have even made beds out of 3/4 inch plexiglass. It really a fairly easy thing to do. If you bolt the bed to the frame from the top you will need to buy a Forstner bit or similiar tool to drill the holes. Or install them from below to not see the bolts Mike |
07-20-2009, 05:47 PM | #3 |
Re: Wood Bed
thanks mike do u have any pictures?
07-20-2009, 06:16 PM | #4 |
Re: Wood Bed
Be aware (to do a correct conversion), there is a lot more to converting from steel to wood than you might think....Trust me, I'm in the process right now....
For one, you need all new cross sills and front header plus the bed needs to come completely apart! "Mark-K" sells everything needed for the conversion.... Here are the "Instructions" http://www.mar-k.com/67-72conv.pdf
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 07-20-2009 at 06:19 PM. |
07-20-2009, 06:17 PM | #5 |
Re: Wood Bed
I have some picture but they are just loose boards or completed beds. You can get all the dimensions off the web at several sites. I think GMCPAULS from what I understand has them on his site. I will see what I have We sell all the parts for the conversion as well and we also sell Mar-k products also.
The bed does have to come apart and yes its work but it is still alot easier then welding. We do this for a living so it probably is easier for us but its not all that hard. Hardest part is taking the bed apart. after that its actually kind of fun if you like this stuff Last edited by mbgmike; 07-20-2009 at 06:20 PM. |
07-20-2009, 07:13 PM | #6 |
Re: Wood Bed
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
07-20-2009, 09:18 PM | #7 |
Re: Wood Bed
ya man i have the bed completely apart right now i knew the head board and the new cross sills had to be replaced but thanks for the helpful info
07-20-2009, 09:19 PM | #8 | |
Re: Wood Bed
